GMH1975 Offline
#1 Posted : Thursday, 30 August 2007 4:46:54 AM(UTC)
GMH1975
Does anyone have a photo or diagram of a factory setup for Hq/Z central locking?
i cant get after market units to work properly and i want to know how holden did it from factory.
Anyne able to help?
Not the BLOODY Kingswood
ozjason Offline
#2 Posted : Thursday, 30 August 2007 6:19:32 PM(UTC)
ozjason
What's your problem with after market? I've fitted it to a HQ, and LH. All fine. Had to clean and re-grease the door lock mechanisms, and adjust the spring so that the solenoids could operate, but it is very possible and easy with some time and patienc
ozjason Offline
#3 Posted : Thursday, 30 August 2007 6:19:32 PM(UTC)
ozjason
Whats your problem with after market? Ive fitted it to a HQ, and LH. All fine. Had to clean and re-grease the door lock mechanisms, and adjust the spring so that the solenoids could operate, but it is very possible and easy with some time and patience.
GMH1975 Offline
#4 Posted: : Sunday, 2 September 2007 11:52:40 PM(UTC)
GMH1975
Hi Jason.
I ajusted the springs and cleaned the locks but i cant get it right.The drivers side front and rear work ok but passenger side is a pain.They open the lock but when you go to open the door from the outside it makes a clunk and wont open.If you
#5 Posted : Tuesday, 4 September 2007 6:44:38 PM(UTC)
Can't help you with the wiring diagram, but you should be able to use the aftermarket relay/controller and connect them to the factory Holden solenoids. Just bear in mind that the aftermarket solenoids have a "master" for the driver's door and the Holden
#6 Posted : Tuesday, 4 September 2007 6:44:38 PM(UTC)
Cant help you with the wiring diagram, but you should be able to use the aftermarket relay/controller and connect them to the factory Holden solenoids. Just bear in mind that the aftermarket solenoids have a "master" for the drivers door and the Holden on
ozjason Offline
#7 Posted : Tuesday, 4 September 2007 6:58:02 PM(UTC)
ozjason
GMH - Im in Bris, so cant help in person, then.
Ok, so it sounds as if the solenoid doesnt have enough "bite" on the rod to unlock. Does it lock fine? Unlock by hand, then trigger central locking to lock it, then try to open the door. All good? May
ozjason Offline
#8 Posted : Tuesday, 4 September 2007 6:58:02 PM(UTC)
ozjason
GMH - I'm in Bris, so can't help in person, then.
Ok, so it sounds as if the solenoid doesn't have enough "bite" on the rod to unlock. Does it lock fine? Unlock by hand, then trigger central locking to lock it, then try to open the door. All good?
