#1 Posted : Saturday, 1 September 2007 6:15:45 AM(UTC)
Any body out there know where to get fuel hose that is ethanol friendly . Tried all ussual outlets But no will guarantee . Any help much appreciated.
#2 Posted : Sunday, 2 September 2007 6:28:27 PM(UTC)
Why is an ethanol hose any different than standard? . . . .
You could use a high Silicone hose if youre worried.
#3 Posted : Sunday, 2 September 2007 6:28:27 PM(UTC)
You could use a high Silicone hose if you're worried.
Munromad2004 Offline
#4 Posted : Sunday, 2 September 2007 11:46:15 PM(UTC)
Munromad2004
Apparently ethanol can break down rubber components such as hoses and seals.
Most large auto manufactures do not recommend running more than 5% ethanol blend fuel in their cars but our government in it's infinite wisdom have decreed that 10% is OK.
#5 Posted : Sunday, 2 September 2007 11:46:15 PM(UTC)
Munromad2004
Most large auto manufactures do not recommend running more than 5% ethanol blend fuel in their cars but our government in its infinite wisdom have decreed that 10% is OK.
M
#6 Posted : Monday, 3 September 2007 3:37:23 AM(UTC)
I know a fellow who was using ethanol in an XF years ago (he works for a producer) and it not only chewed out the fuel hose, but also took out the needle & seat, and the mechanical fuel pump diaphragm.
When he converted it to EFI, he had to get special
#7 Posted : Monday, 3 September 2007 4:00:16 AM(UTC)
Hi Guys.
Modern EFI hose is fine. The petrol companies have put out some very negative info about ethanol, most of it with no basis in fact.
The older style rubber/neoprene hoses will be affected, mostly because they're already 20+ years old & crack
#8 Posted : Monday, 3 September 2007 4:00:16 AM(UTC)
Hi Guys.
The older style rubber/neoprene hoses will be affected, mostly because theyre already 20+ years old & cracke
Sandman Offline
#9 Posted : Wednesday, 5 September 2007 3:15:30 AM(UTC)
Sandman
I use ORTEC hose for fuel lines, trans coolers, oil lines, even heater hose.
Its a red rubber and is fuel and oil resistantant, 250psi pressure rating.
Ive used it on race cars running methanol for yrs without any failures or problems. Last race car was
Sandman Offline
#10 Posted : Wednesday, 5 September 2007 3:15:30 AM(UTC)
Sandman
It's a red rubber and is fuel and oil resistantant, 250psi pressure rating.
I've used it on race cars running methanol for yrs without any failures or problems. Last race car w
