Any body out there know where to get fuel hose that is ethanol friendly . Tried all ussual outlets But no will guarantee . Any help much appreciated.
Why is an ethanol hose any different than standard? . . . . You could use a high Silicone hose if youre worried.
Why is an ethanol hose any different than standard? . . . . You could use a high Silicone hose if you're worried.
Apparently ethanol can break down rubber components such as hoses and seals.
Most large auto manufactures do not recommend running more than 5% ethanol blend fuel in their cars but our government in it's infinite wisdom have decreed that 10% is OK.
Most large auto manufactures do not recommend running more than 5% ethanol blend fuel in their cars but our government in its infinite wisdom have decreed that 10% is OK.
M
I know a fellow who was using ethanol in an XF years ago (he works for a producer) and it not only chewed out the fuel hose, but also took out the needle & seat, and the mechanical fuel pump diaphragm.
When he converted it to EFI, he had to get special |
Hi Guys.
Modern EFI hose is fine. The petrol companies have put out some very negative info about ethanol, most of it with no basis in fact.
The older style rubber/neoprene hoses will be affected, mostly because they're already 20+ years old & crack |
Hi Guys.
The older style rubber/neoprene hoses will be affected, mostly because theyre already 20+ years old & cracke |
I use ORTEC hose for fuel lines, trans coolers, oil lines, even heater hose. Its a red rubber and is fuel and oil resistantant, 250psi pressure rating. Ive used it on race cars running methanol for yrs without any failures or problems. Last race car was
I use ORTEC hose for fuel lines, trans coolers, oil lines, even heater hose. It's a red rubber and is fuel and oil resistantant, 250psi pressure rating. I've used it on race cars running methanol for yrs without any failures or problems. Last race car w
