Munromad2004 Offline
#1 Posted : Saturday, 1 September 2007 9:25:05 AM(UTC)
Munromad2004
Hi all,
Im pretty sure I know the answer to this one but I just wanted to double check it by running it past you guys as I don't like giving out dodgy information.
I have been chatting to someone recently who has just bought a HQ GTS coupe that has been fitted with a HJ GTS dash and he want's to return it to original.
To fit a HJ dash to a HQ I believe you have to cut out the HQ dash frame and weld in the HJ sheet metal and vice versa to revert the dash to original.
Is this correct?
I told him what I believed to be true yet today he says that several other people have told him that it is just a simple bolt in job.
I've got photo's of both my HJ GTS and HQ GTS with the dashes stripped bare and it definitely looks like a cut and shut job will be required.
Am I correct? Qute - I'm pretty sure you've tackled this job haven't you?
regards
Darren
hz dude Offline
#2 Posted : Saturday, 1 September 2007 7:01:20 PM(UTC)
hz dude
hey dude its a bolt in job take the dash out
you need plenty of room so coloum out as well
behind the dash is an alloy frame that unbolts
its a bit of a pain but just change the HJ
frame with a HQ frame and every thing should
go back together fine
HZute-efi-VS5L Offline
#3 Posted : Saturday, 1 September 2007 7:27:12 PM(UTC)
HZute-efi-VS5L
hmm dont think that it totaly correct?
i thought the hq framework (spot welded to the dash) is diferent to the hj etc dash. you may have to cut out a pannel from a q and weld it in.
not 100% sure.
www.stickthisdecals.com.au
BlaDe Offline
#4 Posted : Saturday, 1 September 2007 7:49:55 PM(UTC)
BlaDe
i just put another hz dash in my q ute and the steering didnt have to come out but the only prob i had was the metal part behind the dash was bent down to fit the shap of the hz dash and whoever did it bent it to far so there is a gap at either end. if th
#5 Posted : Saturday, 1 September 2007 8:03:32 PM(UTC)
http://i214.photobucket....2/350tonner/DSCF0360.jpg
http://i214.photobucket....2/350tonner/DSCF0361.jpg
also the bottom left hand lug on the glove box that bolts just in front of the door and behind the kick panel will need a hol
#6 Posted : Sunday, 2 September 2007 4:03:04 AM(UTC)
Munromad2004. You were right it is a weld in job not a bolt in.
Paul.
#7 Posted : Sunday, 2 September 2007 5:44:45 AM(UTC)
Munromad2004
Thanks Paul.
I have photos of my HJ GTS and HQ GTS dashes stripped to the bare bones and the whole structure in completely different.
I can see why this guy was given conflicting information now though. No one seems to know. :-)
Heres the photo
Edited by user Sunday, 2 September 2007 5:58:12 AM(UTC)  | Reason: Not specified
#8 Posted : Sunday, 2 September 2007 5:44:45 AM(UTC)
Munromad2004
Thanks Paul.
I have photo's of my HJ GTS and HQ GTS dashes stripped to the bare bones and the whole structure in completely different.
Here's the pho
