Munromad2004 Offline
#1 Posted : Saturday, 1 September 2007 9:25:05 AM(UTC)
Munromad2004
Hi all,
Im pretty sure I know the answer to this one but I just wanted to double check it by running it past you guys as I don't like giving out dodgy information.
I have been chatting to someone recently who has just bought a HQ GTS coupe that has been fitted with a HJ GTS dash and he want's to return it to original.
To fit a HJ dash to a HQ I believe you have to cut out the HQ dash frame and weld in the HJ sheet metal and vice versa to revert the dash to original.
Is this correct?
I told him what I believed to be true yet today he says that several other people have told him that it is just a simple bolt in job.
I've got photo's of both my HJ GTS and HQ GTS with the dashes stripped bare and it definitely looks like a cut and shut job will be required.
Am I correct? Qute - I'm pretty sure you've tackled this job haven't you?
regards
Darren
hz dude Offline
#2 Posted : Saturday, 1 September 2007 7:01:20 PM(UTC)
hz dude
hey dude its a bolt in job take the dash out
you need plenty of room so coloum out as well
behind the dash is an alloy frame that unbolts
its a bit of a pain but just change the HJ
frame with a HQ frame and every thing should
go back together fine
HZute-efi-VS5L Offline
#3 Posted : Saturday, 1 September 2007 7:27:12 PM(UTC)
HZute-efi-VS5L
hmm dont think that it totaly correct?
i thought the hq framework (spot welded to the dash) is diferent to the hj etc dash. you may have to cut out a pannel from a q and weld it in.
not 100% sure.
www.stickthisdecals.com.au
BlaDe Offline
#4 Posted : Saturday, 1 September 2007 7:49:55 PM(UTC)
BlaDe
i just put another hz dash in my q ute and the steering didnt have to come out but the only prob i had was the metal part behind the dash was bent down to fit the shap of the hz dash and whoever did it bent it to far so there is a gap at either end. if th
#5 Posted : Saturday, 1 September 2007 8:03:32 PM(UTC)
http://i214.photobucket..../350tonner/DSCF0360.jpg
http://i214.photobucket..../350tonner/DSCF0361.jpg
also the bottom left hand lug on the glove box that bolts just in front of the door and behind the kick panel will need a hol
#6 Posted : Sunday, 2 September 2007 4:03:04 AM(UTC)
Munromad2004. You were right it is a weld in job not a bolt in.
Paul.
#7 Posted : Sunday, 2 September 2007 5:44:45 AM(UTC)
Munromad2004
Thanks Paul.
I have photos of my HJ GTS and HQ GTS dashes stripped to the bare bones and the whole structure in completely different.
I can see why this guy was given conflicting information now though. No one seems to know. :-)
Heres the photo
Edited by user Sunday, 2 September 2007 5:58:12 AM(UTC)  | Reason: Not specified
#8 Posted : Sunday, 2 September 2007 5:44:45 AM(UTC)
Munromad2004
Thanks Paul.
I have photo's of my HJ GTS and HQ GTS dashes stripped to the bare bones and the whole structure in completely different.
Here's the pho
This page was generated in 0.104 seconds.
