Holden One Offline
#1 Posted : Sunday, 2 September 2007 4:36:59 AM(UTC)
Holden One
Guys,
Today i purchased an impulse buy a 307 chev engine.
The engine number starts with 307*****K0926
Engine code at the rear of block is 3914636.
Assuming this is an early block, maybe 60s? It also has a 2 barrell which i found unusual.
Anyway have any idea what it was out of?
Jamie
Holden One Offline
#2 Posted : Sunday, 2 September 2007 4:51:03 AM(UTC)
Holden One
Done some checking on the web, it tells me it is a 68 vintage but nothing else...
#3 Posted : Sunday, 2 September 2007 5:04:53 AM(UTC)
The engine number will tell you which plant it came out of and the number will also tell you about when it was installed in a car. Impossible to tell if it was out of a kingswood, Premier, Monaro or Belmont
Warren
Holden One Offline
#4 Posted : Sunday, 2 September 2007 5:11:42 AM(UTC)
Holden One
Hi Warren,
Could i email you directly with the engine number to dissect?
My email is [email protected]
Just wary posting engine numbers on websites.
Jamie
Munromad2004 Offline
#5 Posted : Sunday, 2 September 2007 5:38:49 AM(UTC)
Munromad2004
I thought the 307 came out standard with a 2 barrel?
Slamd Hk Offline
#6 Posted : Tuesday, 4 September 2007 11:18:02 PM(UTC)
Slamd Hk
Hi,
Do you know what 2 barrel carby it is?
I have been trying to find the right 2 barrel for mine & have been told WW Stromberg or a Rochester.
Does anyone know if 2barrel WW's from a 253 fit a standard 2barrel 307 manifold.
Slamd Hk
MLD
Slamd Hk Offline
#7 Posted : Tuesday, 4 September 2007 11:18:02 PM(UTC)
Slamd Hk
Hi,
Does anyone know if 2barrel WWs from a 253 fit a standard 2barrel 307 manifold.
Slamd Hk
MLD
#8 Posted : Tuesday, 4 September 2007 11:42:31 PM(UTC)
Found this info a while back , correct me if I'm wrong. 2 bbl Rochester No 7028114. 702 = 1960'S, 8 = 1968, 1 = 2BBL, 1 = Chevrolet, 4 = auto ( even no auto, odd no manual)
#9 Posted : Tuesday, 4 September 2007 11:42:31 PM(UTC)
Found this info a while back , correct me if Im wrong. 2 bbl Rochester No 7028114. 702 = 1960S, 8 = 1968, 1 = 2BBL, 1 = Chevrolet, 4 = auto ( even no auto, odd no manual)
#10 Posted : Wednesday, 5 September 2007 4:36:09 AM(UTC)
Checked out my 307 and the rochester carb which I think is the original is No 7027114 and date coded D 8 which is the 4 month of 1968. This might help you to find the right 2 BBL Rochester Carb.
Slamd Hk Offline
#11 Posted : Wednesday, 5 September 2007 10:42:26 PM(UTC)
Slamd Hk
thanks Bazza, i will try & search for one from those details, i hate the 350 holley currently on it.
MLD
This page was generated in 0.122 seconds.
