basketcasebear Offline
#1 Posted : Monday, 3 September 2007 4:09:31 AM(UTC)
basketcasebear
hey yall,
whats the best temp range for 308,?
my fan comes on at 80c it is adjusted as low as the switch wil allow me too?
thanks
ptpro
DOH!!!
#2 Posted : Tuesday, 4 September 2007 7:15:49 AM(UTC)
basketcasebear
does anyone know whether 80c is too high temp on 308,???
thanks already
ptpro
DOH!!!
#3 Posted : Tuesday, 4 September 2007 6:14:04 PM(UTC)
HI fb.
No, 80c is not too hot.
Early 308 V8s had an 82c thermostat & from '76 onwards they had an 88c thermostat. These numbers reflect the minimum running temperature.
I'd be setting the fan switch-on at around 86c to 90c, hopefully the switch-
#4 Posted : Tuesday, 4 September 2007 6:14:04 PM(UTC)
HI fb.
Early 308 V8s had an 82c thermostat & from 76 onwards they had an 88c thermostat. These numbers reflect the minimum running temperature.
Id be setting the fan switch-on at around 86c to 90c, hopefully the switch-of
#5 Posted : Wednesday, 5 September 2007 5:25:45 AM(UTC)
basketcasebear
thankyou DR Terry.!
I will reset, the . adjustable resetable adjuster knob, on the adjusting switch.
ptpro
DOH!!!
