hey yall, whats the best temp range for 308,? my fan comes on at 80c it is adjusted as low as the switch wil allow me too? thanks
ptpro |
more than basketcase than a bear! DOH!!! |
does anyone know whether 80c is too high temp on 308,??? thanks already
ptpro |
HI fb.
No, 80c is not too hot.
Early 308 V8s had an 82c thermostat & from '76 onwards they had an 88c thermostat. These numbers reflect the minimum running temperature.
I'd be setting the fan switch-on at around 86c to 90c, hopefully the switch- |
HI fb.
Early 308 V8s had an 82c thermostat & from 76 onwards they had an 88c thermostat. These numbers reflect the minimum running temperature.
Id be setting the fan switch-on at around 86c to 90c, hopefully the switch-of |
thankyou DR Terry.! I will reset, the . adjustable resetable adjuster knob, on the adjusting switch. cheers
ptpro |
