#1 Posted : Wednesday, 5 September 2007 6:12:36 AM(UTC)
Guys
Very cheap 3.45:1 Cross 8 diff on Ebay. Reported as only 12 months / 15000kM old. These are marked on a tag as "high performance" - I noted this last night on mine as I was adjusting the handbrake. I think this just means its a 4 pinion LSD.
You'd have to do something about the front yoke, and the calipers are piped for ABS but still cheap as.
http://cgi.ebay.com.au/H...WDVWQQrdZ1QQcmdZViewItem
#2 Posted : Wednesday, 5 September 2007 8:10:57 AM(UTC)
Just to clarify a bit of your post Byron,
They are all 4 pinion centres.
The open-centre (as used on V8s & commercial V6s) wears a high performance, use approved lubricant tag - this simply denotes that it has shot-peened internals.
The LSD (for
#3 Posted : Wednesday, 5 September 2007 8:10:57 AM(UTC)
The open-centre (as used on V8s & commercial V6s) wears a 'high performance, use approved lubricant' tag - this simply denotes that it has shot-peened internals.
The LSD (fo
#4 Posted : Wednesday, 5 September 2007 4:15:15 PM(UTC)
Cheers Mick. I wasnt sure of the actual ins and outs of these diffs. Just thought itd make a good solid conversion diff for someone with a HQ-WB that had an overdrive box.
If we all had the same
#5 Posted: : Wednesday, 5 September 2007 4:15:15 PM(UTC)
Cheers Mick. I wasn't sure of the actual ins and outs of these diffs. Just thought it'd make a good solid conversion diff for someone with a HQ-WB that had an overdrive box.
