#1 Posted : Thursday, 6 September 2007 2:14:25 AM(UTC)
in what model holden did they first use alloy bridges on the rockers ? cheers
#2 Posted : Thursday, 6 September 2007 2:49:50 AM(UTC)
HI John.
HT 253/308 was the first Holden engine to use alloy rocker bridges. HQ 173/202 was the first 6.
#3 Posted : Friday, 7 September 2007 2:10:51 AM(UTC)
thanks dr terry can you put 173 202 alloy bridge rockers on a 186 head its just that i have a 12 port head of a 186 and the 202 rockers easier to set if not no drama just a thought cheers
FastEHHolden Offline
#4 Posted : Friday, 7 September 2007 4:30:32 AM(UTC)
FastEHHolden
The only difference between a 186 and a 202 head is the rockers...If you were close by i could swap you a 202 head for your 186 head.
#5 Posted : Friday, 7 September 2007 6:32:03 AM(UTC)
You can put the later rockers on an early head. You just have to buy the kit to do it, but im not sure if anyone still makes them.
If we all had the same (good) taste, who would buy all the Fords
#6 Posted : Friday, 7 September 2007 6:32:03 AM(UTC)
You can put the later rockers on an early head. You just have to buy the kit to do it, but i'm not sure if anyone still makes them.
adam PERTH Offline
#7 Posted : Friday, 7 September 2007 7:33:35 AM(UTC)
adam PERTH
186 head, big spark plug,
"kidney chamber"
202 Head, small spark plug that pertrudes the chamber.
- dont mix your push rods.
A1 Bogan.
adam PERTH Offline
#8 Posted : Friday, 7 September 2007 7:33:35 AM(UTC)
adam PERTH
"kidney chamber"
- don't mix your push rods.
A1 Bogan.
#9 Posted : Friday, 7 September 2007 7:24:20 PM(UTC)
"kidney chamber"
adam PERTH Offline
#10 Posted : Friday, 7 September 2007 9:53:59 PM(UTC)
adam PERTH
i thought all big spark plug heads had the "kidney chamber"?
A1 Bogan.
#11 Posted : Friday, 7 September 2007 10:14:28 PM(UTC)
Terry is correct. Where the head is used to set the compression ratio, the small chamber is off the high compression variation, and the big chamber off the low compression variation. This only applies to some engines though, like the 173 (I think this is
