bmg52001 Offline
#1 Posted : Friday, 7 September 2007 5:57:48 PM(UTC)
bmg52001
Hey Guys,
Ive put a new stereo in the old WB Stato & bugger me if I can get the electric aerial to work.If I connect the blue wire from the stereo and the white & red wire from the aerial to the switch I can get the aerial to go up but not down. If I reverse the white & red wires I can get it to go down but not up.However I wire the switch the aerial won't go up when the radio turns on only manually when I press the switch & then the aerial will go all the way up, how can I preset the height?
Any help would be appreciated as I pulling out the little amount of hair I've got.
Thanks BMG52001
#2 Posted : Friday, 7 September 2007 8:49:05 PM(UTC)
You need the electric aerial control module to be wired in.
Is it still in the car?
From the sounds of it, you are bypassing the module & going straight to the aerial.
If you do this, you need to put the red wire to constant 12V+, and hook the bl
bmg52001 Offline
#3 Posted : Friday, 7 September 2007 9:36:50 PM(UTC)
bmg52001
Thanks Mick,Where do I find the module & what does it look like?
BMG52001
#4 Posted : Saturday, 8 September 2007 2:35:50 AM(UTC)
I'm not sure in a WB, one of the guys like Byron, Johnperth or Rhys would be better at that.
It is about 2 inches wide, by 2 inches tall, and about an inch thick, with a plug on the bottom.
The early ones are a 6 pin plug, the later ones an 8 pin plug
#5 Posted : Saturday, 8 September 2007 2:35:50 AM(UTC)
Im not sure in a WB, one of the guys like Byron, Johnperth or Rhys would be better at that.
#6 Posted : Saturday, 8 September 2007 9:22:06 AM(UTC)
sorry thanks for the vote of confidence but I have no idea. try an audio fitter they would probably answer a simple question for free. were these auto up anyway? also are you using a 3 way (up-neutral-down) switch?
#7 Posted : Monday, 10 September 2007 5:52:40 PM(UTC)
Thanks guys,
Ill have a look tonite & give it a go. Yes it does have the 3 way switch.
BMG52001
#8 Posted : Monday, 10 September 2007 5:52:40 PM(UTC)
Thanks guys,
I'll have a look tonite & give it a go. Yes it does have the 3 way switch.
BMG52001
Rhys Offline
#9 Posted : Saturday, 8 December 2007 5:56:21 AM(UTC)
Rhys
Hi BMG52001,
Not sure if you've solved this yet or not but I might be able to help if you haven't. The aerial control module on a WB Statesman is mounted up under the dash with a heap of other relays on the passenger side of the steering column. As Mic
Rhys Offline
#10 Posted : Saturday, 8 December 2007 5:56:21 AM(UTC)
Rhys
Hi BMG52001,
Not sure if youve solved this yet or not but I might be able to help if you havent. The aerial control module on a WB Statesman is mounted up under the dash with a heap of other relays on the passenger side of the steering column. As Mick
Guest (8)
