Handgunner Offline
#1 Posted : Sunday, 9 September 2007 8:47:41 PM(UTC)
Handgunner
Hi all, i will be using a Turbo 400 behind a 220... ish HP 307 built for torque, standard rams horn manifolds, 450 cfm carb , 9.00 compression, gas with suitable cam 1800 - 4500 ..standard chev heads shaved zero deck block..etc.... and a .308 Diff.( Hg Van )... can someone tell me what my chev will rev at at say ,100 klm... and how will it go with the 400 ratios...? I have heard that the 350 box ratios are better? Why ? This Van is just for general cruising and hi way driving... also , what will the
400 stall speed be with this combo? Not sure how much torque it will make.. same as a standard 307 i guess..
Bang Bang
Bang Bang
Sandman Offline
#2 Posted : Monday, 10 September 2007 5:22:05 AM(UTC)
Sandman
TH400 is 248 1st, 1.48 2nd, 1.0 top gear.
TH350 is 2.52 1st, 1.52 2nd, 1.0 top.
Not much difference!
I have been told that a TH400 soaks up a bit more HP because they use overrunning sprags and clutch packs instead of bands and clutches,
but I couldn
adam PERTH Offline
#3 Posted : Monday, 10 September 2007 7:34:01 AM(UTC)
adam PERTH
HG?
May be cheaper to go for the T350 short snout (common).
use original tailshaft, have to modify crossmember though.
and slightly smaller to fit T350 into HG transmission tunnel than a T400 (Larger diameter).
SOme of the early T350's have a cable ki
adam PERTH Offline
#4 Posted : Monday, 10 September 2007 7:34:01 AM(UTC)
adam PERTH
HG?
SOme of the early T350s have a cable kic
#5 Posted : Monday, 10 September 2007 4:35:30 PM(UTC)
Originally posted by adam PERTH
SOme of the early T350s have a cable kickdown, same as HG also.
A1 Bogan.
#6 Posted : Monday, 10 September 2007 4:35:30 PM(UTC)
SOme of the early T350's have a cable kickdown, same as HG also.
A1 Bogan.
adam PERTH Offline
#7 Posted : Tuesday, 11 September 2007 3:28:02 AM(UTC)
adam PERTH
DR Terry,
So, you are saying that you have never seen a non - cable kickdown T350?
A1 Bogan.
#8 Posted : Tuesday, 11 September 2007 4:32:27 AM(UTC)
Was thanked: 605 time(s) in 572 post(s)
Terry
Cut and paste off another web page. This is probably why Holden stopped using them in WB and VH:
The pre-81 TH350 uses a detent cable to activate the gearshifts and passing-gear kickdown. You must use a detent with these units, or the transmis
Edited by user Tuesday, 11 September 2007 4:35:38 AM(UTC)  | Reason: Not specified
#9 Posted : Tuesday, 11 September 2007 4:32:27 AM(UTC)
Terry
The pre-'81 TH350 uses a detent cable to activate the gearshifts and passing-gear kickdown. You must use a detent with these units, or the transmi
#10 Posted : Tuesday, 11 September 2007 5:43:51 AM(UTC)
Hi Guys.
Yes, I've heard of the TH350C, but they were only made for less than 2 years & I've never actually seen one. The 'normal' TH350 was made for 12 years.
I knew the TH350C had a lock-up converter but did not know they had no cable kickdown.
#11 Posted : Tuesday, 11 September 2007 5:43:51 AM(UTC)
Hi Guys.
Yes, Ive heard of the TH350C, but they were only made for less than 2 years & Ive never actually seen one. The normal TH350 was made for 12 years.
In
#12 Posted : Tuesday, 11 September 2007 7:34:34 AM(UTC)
It was news to me too, and like you I knew of the lockup converter but not the electric kickdown. I've often heard of a TH200 with a lockup converter too.
If we all had the same (good) taste, who
#13 Posted : Tuesday, 11 September 2007 7:34:34 AM(UTC)
It was news to me too, and like you I knew of the lockup converter but not the electric kickdown. Ive often heard of a TH200 with a lockup converter too.
adam PERTH Offline
#14 Posted : Wednesday, 12 September 2007 5:50:28 AM(UTC)
adam PERTH
Bryon, if i email you a pic of the T350 3C, to upload if you like.
i don't know how to.
There are actually 3 different types of extension housings avail on the T350
Short nout
Mid snout
Long snout
I have never seen a short snout that WASN't Cable
adam PERTH Offline
#15 Posted : Wednesday, 12 September 2007 5:50:28 AM(UTC)
adam PERTH
i dont know how to.
Short nout
Mid snout
Long snout
I have never seen a short snout that WASNt Cable.
