MuckUte Offline
#1 Posted : Monday, 10 September 2007 3:55:28 AM(UTC)
MuckUte
Is it possible to buy new the small loom that goes between the coil and distributor because mine has become very brittle and the insulation is falling off.
#2 Posted : Monday, 10 September 2007 4:10:57 AM(UTC)
I doubt it, but its not hard to make your own new one with some wire & a few crimp terminals.
A lot of people aim to achieve nothing in life - and have amazing accuracy
#3 Posted : Monday, 10 September 2007 4:10:57 AM(UTC)
I doubt it, but it's not hard to make your own new one with some wire & a few crimp terminals.
ozjason Offline
#4 Posted : Monday, 10 September 2007 8:11:49 PM(UTC)
ozjason
Quick fix that'll get you by and save you from a fire would be to put some 5mm heat shrink over the whole thing. Still the same old wire inside, but at least the insulation is ok then.
Shouldn't leave it like that forever, though - Mick's spot on with
ozjason Offline
#5 Posted : Monday, 10 September 2007 8:11:49 PM(UTC)
ozjason
Quick fix thatll get you by and save you from a fire would be to put some 5mm heat shrink over the whole thing. Still the same old wire inside, but at least the insulation is ok then.
Shouldnt leave it like that forever, though - Micks spot on with ma
