tenticles Offline
#1 Posted : Wednesday, 12 September 2007 4:49:41 PM(UTC)
tenticles
hi, what is the best 4/5 speed gearbox to fit to my HQ?
eventually, i will be fitting a mild 350 on LPG to my ute. i have an iron celica gearbox, but browsing these pages, think it may be unsuitable
i also have a toploader from a 6 cylinder cortina, wondering if thats a goer
or should i go oem with a usa muncie or T5 etc ?
thanx in advance, johnny
yes sonny, it's an HQ ute
#2 Posted : Wednesday, 12 September 2007 10:17:36 PM(UTC)
If it was my car I'd fit a TH400 and a 2.6:1 diff. If you want even stronger diff wise a 2.5 or 2.75:1 9" (you won't get a stonger box than the Th400).
For a manual I would use a Muncie. But if you already have a toploader then use it. The advantage of
#3 Posted : Wednesday, 12 September 2007 10:17:36 PM(UTC)
If it was my car Id fit a TH400 and a 2.6:1 diff. If you want even stronger diff wise a 2.5 or 2.75:1 9" (you wont get a stonger box than the Th400).
For a manual I would use a Muncie. But if you already have a toploader then use it. The advantage of t
adam PERTH Offline
#4 Posted : Thursday, 13 September 2007 12:25:41 AM(UTC)
adam PERTH
got a supra 5 sp conversion into V8 1 tonner with CRS bellhousing, crossmember, clutch and 1 ton tailshaft.
$1200.
A1 Bogan.
