#1 Posted : Thursday, 13 September 2007 5:06:03 PM(UTC)
hi has any one seen a vs v6 running hot the fans dont come on till 3/4 on the gauge, ecu temp sender problem or ecu?????
does the ecu have a memcal like a vn or is it hard programmed to it?
can the ecu be replaced or does it have to be reprogrammed at holden?
thanks.
#2 Posted : Thursday, 13 September 2007 5:53:35 PM(UTC)
Hi petaus.
VS V6s have a 2-speed fan. Its common for 1 speed to work & the other not. In other words the 1st stage is not working & when it gets extra hot the 2nd stage comes in later.
VS ECUs have a plug-in mem-cal but its probably the most reliabl
#3 Posted : Thursday, 13 September 2007 5:53:35 PM(UTC)
Hi petaus.
VS V6s have a 2-speed fan. It's common for 1 speed to work & the other not. In other words the 1st stage is not working & when it gets extra hot the 2nd stage comes in later.
VS ECUs have a plug-in mem-cal but it's probably the most relia
#4 Posted : Thursday, 13 September 2007 6:27:34 PM(UTC)
hi terry it,s a statesman both fan,s low and hi seem to be working they just come in so hot,i changed thesender for the gauge i remember first vs had a recall for this, i dont have excess to a scanner i,ll see if can get any codes from the light
JBM Offline
#5 Posted : Friday, 21 September 2007 10:27:36 AM(UTC)
JBM
Have you checked the rest of the cooling system, at about 150,000 kms you may need to replace the water pump.
James
#6 Posted : Friday, 21 September 2007 4:13:48 PM(UTC)
I would get the engine and radiator power flushed, before flushing use `mukowt` as per instruction and replace the thermostst.my vr has just had this done.
