keithholden Offline
#1 Posted : Monday, 17 September 2007 4:28:07 AM(UTC)
keithholden
Hi ive been trying to get my choke flap out of one carb and put in my carb its a 600 holley. The flap has 3 tags and looks like it slots into a kind of rod. Ive tried pushing on it with screw driver to push tag in but no luck
I dont want to damage the choke .. It doesnt have any screws only tags
Advice appreciated.. the car wont idle while cold so i need a choke
Edited by user Monday, 17 September 2007 7:22:18 AM(UTC)  | Reason: Not specified
keithholden Offline
#2 Posted : Monday, 17 September 2007 4:47:18 AM(UTC)
keithholden
Pickey of prob http://img241.imageshack...php?image=mvc047fgp6.jpg
jabba Offline
#3 Posted : Monday, 17 September 2007 2:58:54 PM(UTC)
jabba
Where in NZ are you?
I have the holley 4150 / 4160 rebuild / recon / tweak manual, so could get you the info.
j
keithholden Offline
#4 Posted : Monday, 17 September 2007 10:12:29 PM(UTC)
keithholden
Im in chch. Only 2 probs I have with my carb is to swap the choke over from this one and a leaky accelerator pump so will also swap this one over.
But just dont want to wreak the chock flap by banging it to much so wanted to check how others removed it
jabba Offline
#5 Posted : Monday, 17 September 2007 11:10:39 PM(UTC)
jabba
The pikkies I have all show screws in the choke flap. Try the Holley website, it usually has basic servicing guides (and they will respond to requests for assistance reasonably rapidly).
j
Keep the shiny
keithholden Offline
#6 Posted : Tuesday, 18 September 2007 4:21:12 AM(UTC)
keithholden
Hi checked ther site but no luck they prob dont think the choke flap should have to come out for any reason but ive emailed them so will wait and see if I get a reply cheers for that.
keithholden Offline
#7 Posted : Thursday, 20 September 2007 6:41:58 AM(UTC)
keithholden
message from holley will try next few days ,,
HI,
thanks for your e-mail
all you need to do is pry up from the bottom of the choke plate
keithholden Offline
#8 Posted : Sunday, 23 September 2007 2:54:53 AM(UTC)
keithholden
I managed to pry the choke up today with a screw driver and it came out. I was a little worried about breaking the castings but nope all good..
Now my next problem the choke didnt fit my other carb ahhh the hole is to small for the rod to go through.
#9 Posted : Tuesday, 25 September 2007 10:15:53 PM(UTC)
Or drill your good Holley so that you can fit the larger choke shaft to it.
It shi ts me to tears when the media & state politicians refer to the Fede
carbyman Offline
#10 Posted : Saturday, 27 October 2007 10:40:45 AM(UTC)
carbyman
NEXT TIME GET A SMALL FLAT BLADE SCREW DRIVER AND A SMALL HAMMER AND SPREAD THE SHAFT SLIGHTLY BETWEEN THE FLAP AND THE SHAFT THIS WILL RELEIVE THE PRESSURE AND THE FLAP WILL COME OUT ONCE ITS OUT SQUEEZE THE SHAFT BACK TOGETHER AND AND IT WILL ALL BE DON
carbys live
Guest (6)
This page was generated in 0.065 seconds.
