keithholden Offline
#1 Posted : Thursday, 20 September 2007 11:49:32 PM(UTC)
keithholden
My wires are all hooked up to my chev but ive got this problem with my ignition. When I turn it there is a little plastic sprocket in the column that jumps the teeth on the shaft that goes down to ign box.
I then cant turn it far enough to start car. I then take it apart and put it right but it keeps doing the same thing.. I even brought a new plastic sprocket. that the ign goes into but no luck..
Any one have any answers to this?? sick of taking it apart
Cheers in advance
keithholden Offline
#2 Posted : Sunday, 23 September 2007 2:47:02 AM(UTC)
keithholden
Well guys I think ive fixed it but hope I dont jinks my self.
I took the top of column apart and took out ignition the little plastic sprocket that the ignition goes into. The rod that goes down the column and I even took ignition switch off to test it.
keithholden Offline
#3 Posted : Sunday, 23 September 2007 2:50:52 AM(UTC)
keithholden
This is what I mean when this problem arised.
Is it the ignition switch to hard to push causing the jumping of sprocket.
Is it the small spring steel not pushing hard enough on the rod.
Is the housing warn.
Is the sprocket teeth to worn.
Its ok if yo
