sportycorty Offline
#1 Posted : Friday, 21 September 2007 5:20:38 AM(UTC)
sportycorty
NA fairlane 3spd auto
3.9L multipoint injected, ruff idle, revs good and punchy but put it in drive beyond a joke take off power, sometimes stalls. drives ok at higher revs. rotor button and cap new, coil looks to have been replaced. have no idea where to start?
christoss Offline
#2 Posted : Friday, 21 September 2007 7:58:42 AM(UTC)
christoss
try checking your base timing
Ignition Timing (Base)
Engine to Operating Temperature.
Engine at Correct Idle Speed.
Stop Engine
Connect Timing Light.
Connect Jumper Wire between the Terminals on the Diagnostic Connector.
Start Engine.
Set Tim
christoss Offline
#3 Posted : Friday, 21 September 2007 8:06:03 AM(UTC)
christoss
also check basics like fuel filter, air filter, Fuel quality, spark plugs, h/t leads, vacuum leaks(get a can of carby clean and spray around intake manifold gasket, vac hoses, throttle body and anywhere else you can think of)
remove air cleaner lid and s
sportycorty Offline
#4 Posted : Monday, 1 October 2007 12:45:41 AM(UTC)
sportycorty
i havnt got a lend of a timing light yet but can find any vacuum leaks and tried a map sensor from another car no luck. sometimes blows black smoke tho
#5 Posted : Sunday, 21 October 2007 3:09:30 AM(UTC)
Hs it had a manifold gasket replacement? They may have fitted a CFI gasket on it which effects injector spray on the multipoints
