Fred Offline
#1 Posted : Tuesday, 25 September 2007 10:07:53 AM(UTC)
Fred
Just wondering is a trimatic an automatic gearbox and if so does it have 3 speeds.
God is Dog spelt backwards.
#2 Posted : Tuesday, 25 September 2007 4:09:19 PM(UTC)
Yes to both.
Fred Offline
#3 Posted : Tuesday, 25 September 2007 5:36:33 PM(UTC)
Fred
Ok then, I have a gearbox cross member from a HQ Holden that had a 3 speed manual would this cross member take the Trimatic without having to alter the mounting points. Did all HQ to HZs use the same cross member.
Fred Offline
#4 Posted : Tuesday, 25 September 2007 5:36:33 PM(UTC)
Fred
Ok then, I have a gearbox cross member from a HQ Holden that had a 3 speed manual would this cross member take the Trimatic without having to alter the mounting points. Did all HQ to HZ's use the same cross member.
#5 Posted : Tuesday, 25 September 2007 10:05:12 PM(UTC)
Yes the 3spd crossmember will suit the trimatic. HQ-WB all used the same crossmember for the same gearbox and the same chassis. By the same chassis I mean HQ-WB sedan/wagon/statesman are the same and ute/van/tonner are the same. There are other gearboxes
