mmazz30 Offline
#1 Posted : Monday, 1 October 2007 5:45:26 AM(UTC)
mmazz30
After approx 3 months of hard yakka,my backyard EFI project
using my original pre-pollution manifold,and VN V8/V6 hardware
and any other Holden bits and pieces i could scavenge from the wreckers and V8 Delco software with modified V6 loom into a V8 loom,
the beast came alive today.It started,idled quite well,and took it for a drive and drives very well with no major hiccups considering no VSS fitted yet.Done a short d/l dump of files onto Winaldl/Winview and will suss out all calibrations so i can modify the files to extract more power/economy/idle/etc.
Project was done because i wanted to learn to TIG weld,fabricate my own parts,use ONLY holden bits and pieces i could get/modify,get familiar with Delco EFI hardware/software.
My next step is to learn to modify the files and burn to my memcal.
I could have used all the VN top end and be done with it,but i wanted the challenge and wanted to keep my engine bay semi original in my HJ coupe.
ALL the work was done in my shed/lounge room and the biggest cost was 2 bottles of Argon for my TIG welder.
Cheers....Mario
http://s199.photobucket....nt=EFIManifoldpaint5.jpg
http://s199.photobucket....nt=EFIManifoldpaint4.jpg
http://s199.photobucket....nt=EFIManifoldpaint3.jpg
http://s199.photobucket....nt=EFIManifoldpaint2.jpg
http://s199.photobucket....ent=EFImanifoldpaint.jpg
ED57FE Offline
#2 Posted : Friday, 5 October 2007 4:01:50 AM(UTC)
ED57FE
very talented Mario!
I'm impressed.. nice work
Ed
ED57FE Offline
#3 Posted : Friday, 5 October 2007 4:01:50 AM(UTC)
ED57FE
Im impressed.. nice work
Ed
mmazz30 Offline
#4 Posted : Friday, 5 October 2007 8:35:12 AM(UTC)
mmazz30
Thanx Ed,at some stages i wondered if it was worth the effort as i was trying to tig weld 30 y/old cast aluminium and all the crap coming out of it was unbelievable no matter how good i cleaned,ground back,welded,ground back,cleaned etc,etc,then making ev
ED57FE Offline
#5 Posted : Friday, 5 October 2007 5:45:04 PM(UTC)
ED57FE
Hey mario,
I agree I reckon the Delco 808 is a great EFI set up.
im running mine on a Harrop dual plane manifold with EFI hardware throttle body.
I also put mine together from a V6 loom, and all wrecker sourced parts, it sure beats stuffing about w
mmazz30 Offline
#6 Posted : Sunday, 7 October 2007 12:59:04 AM(UTC)
mmazz30
Ed if you didnt already know,visit Just Commodores.com.au all the info u need on DIY programming for the 808 Delco is there.
Around $60.00 on a programmer and bits and pieces and your up and running.People like Dr.Bob,Greenfoam and Spanners are great for
mmazz30 Offline
#7 Posted : Sunday, 7 October 2007 12:59:04 AM(UTC)
mmazz30
Ed if you didn't already know,visit Just Commodores.com.au all the info u need on DIY programming for the 808 Delco is there.
ED57FE Offline
#8 Posted : Monday, 15 October 2007 6:34:20 PM(UTC)
ED57FE
thanks Mario,
I wasnt aware of that much cheaper option
I'll check it out.
Ed
ED57FE Offline
#9 Posted : Monday, 15 October 2007 6:34:20 PM(UTC)
ED57FE
thanks Mario,
Ill check it out.
Ed
This page was generated in 0.088 seconds.
