myxc351 Offline
#1 Posted : Monday, 1 October 2007 8:36:43 AM(UTC)
myxc351
Hi guys, am new to this forum but was hoping someone out there could tell me what to do to get my brakes working on my xc coupe... its been sitting for several years and i've just managed to get it running today.
However brake pedal goes straight to floor and my attempt at bleeding brakes not working... I think i've pumped the pedal at least 5000 times and nothing comes out at wheel cylinders nor does pedal get harder. somebody tell me its an easy fix???
thanks
Munromad2004 Offline
#2 Posted : Monday, 1 October 2007 10:37:45 AM(UTC)
Munromad2004
It's a bit hard to say but assuming everything is still in working order are you sure you're bleeding the brakes correctly?
Give us a quick run down on the procedure you are using.
myxc351 Offline
#3 Posted : Monday, 1 October 2007 7:21:41 PM(UTC)
myxc351
I've put car up on stands and wheels off.
was on my own so just undone bleed valve at right rear and took cap off master cylinder, hoping it would just gravity feed through.
Went away and done some other work.
Came back few hours later and not a drop
Paul351xb Offline
#4 Posted : Tuesday, 2 October 2007 3:31:22 AM(UTC)
Paul351xb
Mastercylinder dead perhaps?
6pak Offline
#5 Posted : Tuesday, 2 October 2007 7:15:42 AM(UTC)
6pak
My ZD sat around for ages being rebuilt. I fitted new everything for the braking system except for the steel lines and that's where I hit a snag. They were blocked with solidified crud. I put a rag over the end and shot compressed air through them to c
myxc351 Offline
#6 Posted : Tuesday, 2 October 2007 6:59:46 PM(UTC)
myxc351
Pulled down master cylinder and thoroughly cleaned it out... tried blowing air through lines....nothing comes out other end, thats where my problem is... have started disconnecting each component of my brake lines and reaming them with "Mig Wire" so far
