Ok folks, whats the concensus ?? The tri is leaking oodles of green fluid from the inspection cover on the trimatic. The engine is a 253.
Am I correct in assuming that there are some Welsh plugs at the rear of the block ? I cant get the inspection cover off to see for sure.
If I am correct, can they be changed with the block in place and work with the TRI out, or just pull the donk and do the lot ?
Of course if there are NO plugs there, what else ?? A cracked block ?
TIA, John
Yes there are welch plugs on the rear of the block and this is where the water will be coming from. I asked this question about 3 months ago as I had the same problem. The answer is yes it can be done in place by removing the tranny and tilting the engi |
202 and three on the tree, can't get more Aussie than that!! |
Peter,
Next dumb question. Is it possible to leave the trannie in place and just pull the motor out ? I have a feeling the Oil sump lump with fowl with the cross member. It just saves disconnecting all those linkages and cables. Urgh.
John
You can but its awkward. Best to remove the whole front panels and slide the motor forward off the box. the convertor will leak gallons of oil so disconnect it from the flywheel. Probably easier really to remove the lot. but do drain the transmission oi
a jack at the front of the tranny unbolt the converter lift the enginr past the engine mounts, with a screwdriver split the tranny/engine apart be careful, ounce apart lift away, but if its coming out in one then a spare yoke will do wonders replace t |
On The Other Hand There's Finger's |
Sounds like a 50/50 bet, When I had a HD I had to do it in one piece due to the oil pan issue.
So off with the bonnet, off with teh prop shaft, all the sundries and see how we go. I must admit undoing the torque converter locking it back as in the GMH
Just pull the motor out and leave the transmission in place. Easy on HQ-WB. Just need a trolley jack and lump of wood under the transmission pan. Couple of tips:
Get some longer bolts the same thread as the ones that hold the tranny to the block, and u |
Thanks for the tip Byron.
AS I HAVE to pull the bloody thing out of the car, I figured do ALL welch plugs as a matter fo course anyway. Then....
Flush and degrease the block too while I am at it. Inspect clean and repaint the sump (add new gasket),
with the 6 cyl holden, i have found it easier to pull motor and box when the trans is manual, WHY? even aliging clutch up with dummy shaft, and load leveler, when you are by yourself, it can take a little effort to get it all square, because they are no |
If youre pulling the sump off, use a new genuine sump gasket. They are one piece, easy to install and dont leak.
If you're pulling the sump off, use a new genuine sump gasket. They are one piece, easy to install and don't leak.
Hi Adam, yes agree with u. I had a HD with powerglide. The only way to get the 179 out was with the tranny. PLus with other cars I have owned and worked on..I know all too well about the spigot alignment.
And yes Byron, new gaskets every time an old on
I think you missed my point. Not NEW, but GENUINE. Genuine are all neoprene one piece, hence no cork and ugly joints.
hi byron those one piece sump gasket are they for a holden 6 or v8 or both ? and who stocks them cheers
V8. Genuine Holden.
