ianb Offline
#1 Posted : Monday, 1 October 2007 8:18:57 PM(UTC)
ianb
hi, i have a hx sandman and last year replaced the engine fan with a pair of thermos, when on a run the engine would get hot and then lose some fluid when the car was stopped. I replaced the thermos with the original fixed fan and have had no trouble since, but can anyone tell me what the difference is between the fixed fan type that i have and the clutch type fans available on the v8 and will it fit directly onto the front of a red 253 and cool properly.
thanks, Ian.
#2 Posted : Monday, 1 October 2007 10:26:15 PM(UTC)
Ian.
This is how to do this:
Replace the red water pump with a late model one (I think it's WB on but just get one for a VN and it'll be right).
Get a water pump pulley off a vehicle that uses the longer nose pump, again VN-VSIII will do.
Get a HQ-H
#3 Posted : Monday, 1 October 2007 10:26:15 PM(UTC)
Ian.
Replace the red water pump with a late model one (I think its WB on but just get one for a VN and itll be right).
Get a HQ-HZ
#4 Posted : Tuesday, 2 October 2007 6:44:06 AM(UTC)
Hey Byron, on the subject of overheating engines what would be the ideal space between fan and radiator?
Ive got a car that overheats in traffic and long highway trips, but cools down once the air flow is back.
HkDave
#5 Posted : Tuesday, 2 October 2007 6:44:06 AM(UTC)
I've got a car that overheats in traffic and long highway trips, but cools down once the air flow is back.
HkDave
#6 Posted : Tuesday, 2 October 2007 7:25:09 AM(UTC)
Not sure. But fan to shroud is very important. And in my experience electrics just dont hack it especially with 350s, but others have different experiences.
If we all had the same (good) taste, w
#7 Posted : Tuesday, 2 October 2007 7:25:09 AM(UTC)
Not sure. But fan to shroud is very important. And in my experience electrics just don't hack it especially with 350's, but others have different experiences.
ianb Offline
#8 Posted : Tuesday, 2 October 2007 7:37:55 AM(UTC)
ianb
thanks Byron, ill look into all that as the van will be out of the garage now that the rain seems to have gone for a while.thanks for your help.
ianb Offline
#9 Posted : Tuesday, 2 October 2007 7:37:55 AM(UTC)
ianb
thanks Byron, i'll look into all that as the van will be out of the garage now that the rain seems to have gone for a while.thanks for your help.
adam PERTH Offline
#10 Posted : Tuesday, 2 October 2007 7:41:22 AM(UTC)
adam PERTH
I had a WB ute 350 chev @ + 40 thou and auto in the Pilbara.
producing around 375 flywheel HP.
I drove it from Tasmania, where it was fine.
as soon as i got there
I tried alot to cool it down.
Eventually, 82 Deg thermostat (with the little brass f
