#1 Posted : Monday, 1 October 2007 9:46:53 PM(UTC)
hi people have xc gs and i beleive it has had a 351 put in it apposed to its original 302 can anyone help me with engine no verification the number is ALIJSL435C51 any help would be great
#2 Posted : Tuesday, 2 October 2007 3:07:45 AM(UTC)
i have done some research on this number and all i can seem to find is that ac cobras from 66-68 had a alijsl engine number but would like some sought of confirmation as ford cant help me....
Paul351xb Offline
#3 Posted : Tuesday, 2 October 2007 3:27:54 AM(UTC)
Paul351xb
OK, process of elimination here. Going by the engine code I'm guessing this puppy is a US sourced engine. Seeing as how no 302 Clevelands were made in the US it's a pretty sure bet that the motor is a 351. We are talking Clevelands here and not Windsor
#4 Posted : Tuesday, 2 October 2007 3:55:35 AM(UTC)
to be honest im not sure wether clevo or windsor
Paul351xb Offline
#5 Posted : Tuesday, 2 October 2007 2:58:03 PM(UTC)
Paul351xb
quick way to tell. Top radiator hose, does it go into the inlet manifold or into the block? Manifold is Windsor and block is clevo.
XB351 Offline
#6 Posted : Saturday, 6 October 2007 7:37:09 PM(UTC)
XB351
the engine has an F series truck engine code. The engine will be from a F100 or F250. Winsors have the radiator hose going to the manifold. Clevo's dont run water in the manifold.
xcjem Offline
#7 Posted : Sunday, 2 December 2007 7:24:31 PM(UTC)
xcjem
Hi i have the same problem as you robbo. Ford couldn't give me ny info but ive been told it could be out of an f100.
Regards, Anthony
Paull Offline
#8 Posted : Wednesday, 26 December 2007 11:39:09 PM(UTC)
Paull
This should help
The VIN on the engine or car will be 6 characters long, for example, JG63UM or AL1JYM. These are decoded as follows;
First character = Product source.
A = USA, C = UK, J = Australia and S = Japan. Am not sure what U is, could be Th
#9 Posted : Sunday, 13 April 2008 7:09:08 AM(UTC)
could u help me with this engine number its out of an 81 xd
JH7INA
42566k
[x/d]
Paull Offline
#10 Posted : Tuesday, 15 April 2008 3:55:32 PM(UTC)
Paull
This one doesn't quite make sense as there were no LTD's made at the Brisbane plant in 1973. That is, N = 1973. Your number should be JG71NA not JH71NA. In othere words, you have either got the 71 wrong or the year wrong.
#11 Posted : Thursday, 17 April 2008 9:18:42 AM(UTC)
mate i found out it is actually
JH71UA
42566K
and do u know why some xd to xf have a hole or some have a plate tak welded over it on the top pannel between the shoky tower and wher the guards bolt on up towards the fire wall on the right hand side
#12 Posted : Monday, 25 August 2008 11:04:48 AM(UTC)
That makes it a LTD made in Queensland - Nov 1978
Guest (10)
