Davesmonaro68 Offline
#1 Posted : Tuesday, 2 October 2007 6:46:51 AM(UTC)
Davesmonaro68
Hey fellas i took a head of a black 3.3 today and found it to be a small chamber head . Would this be a true black head or just a blue 173 that someone would have put on.Also anyone no what a standard cc's are for a black/blue open and closed chambers are?
Dave
MONARO!!WHERE!!NICE
MONARO!!WHERE!!NICE
#2 Posted : Tuesday, 2 October 2007 7:17:39 AM(UTC)
It'll be a blue 173 head.
#3 Posted : Tuesday, 2 October 2007 7:17:39 AM(UTC)
Itll be a blue 173 head.
#4 Posted : Tuesday, 2 October 2007 8:18:22 PM(UTC)
Davesmonaro68
Thanks Byron i thought so , do you have any idea on the standard cc of this head ive heard around 50 cc would this be right.
MONARO!!WHERE!!NICE
MONARO!!WHERE!!NICE
#5 Posted : Tuesday, 2 October 2007 8:18:22 PM(UTC)
Davesmonaro68
Thanks Byron i thought so , do you have any idea on the standard cc of this head i've heard around 50 cc would this be right.
MONARO!!WHERE!!NICE
MONARO!!WHERE!!NICE
#6 Posted : Tuesday, 2 October 2007 9:56:30 PM(UTC)
Not really sure. I think it's the same compression ratio as a 149/161/173 high comp red head. This is the same chamber that the 202 XU-1 engine used (red 161HC head) and they were about 10.5:1, but from memory they used slightly higher comp pistons than s
#7 Posted : Tuesday, 2 October 2007 9:56:30 PM(UTC)
Not really sure. I think its the same compression ratio as a 149/161/173 high comp red head. This is the same chamber that the 202 XU-1 engine used (red 161HC head) and they were about 10.5:1, but from memory they used slightly higher comp pistons than st
#8 Posted : Tuesday, 2 October 2007 10:03:31 PM(UTC)
Hi Davesmonaro68
The nominal combustion chamber sizes for Holden 6 cyl engines are 45 cc for the small chamber and 54 cc for the large chamber. AFAIK this is for Red, Blue & Black.
Dr Terry.
#9 Posted : Tuesday, 2 October 2007 11:44:00 PM(UTC)
Davesmonaro68
i dont have a cc measure but done it with mm and cameup with 50 on the small chamber and 58mm on the large standard chamber , is cc and mm the same or is there a conversion for this.
Dave
MONARO!!WHERE!!NICE
MONARO!!WHERE!!NICE
vintageholden Offline
#10 Posted : Wednesday, 3 October 2007 12:25:19 AM(UTC)
vintageholden
i,m after a blk head for 202 if anyone has one for sale
0414066155
perth
#11 Posted : Wednesday, 3 October 2007 1:08:46 AM(UTC)
#12 Posted : Wednesday, 3 October 2007 2:55:15 AM(UTC)
Davesmonaro68
[/quote]
Hi Dave
cc = ml (mm is linear measurement, cc/ml is volume)
[/quote]
Stupid me i meant ml not mm
MONARO!!WHERE!!NICE
MONARO!!WHERE!!NICE
