Buz Offline
#1 Posted : Thursday, 4 October 2007 12:52:56 AM(UTC)
Buz
The old V6 is running very rough. According to the diagnostic the error codes are 13, 14 & 45. Im having trouble actually locating the sensors to check them, can anyone help?
Thanks.
13 Oxygen sensor output remained at .35-.55 volts for more than one
minute after warmup. Possible open circuit.
14 Coolant sensor indicated a temperature above 130C for 3 seconds
after engine ran for 20 seconds. Probably a short
45 O2 sensor showed > 0.550 volt for over 50 seconds while in
closed loop with engine running over 1 minute and throttle open
more than 2%
** Don't drive like a dickhead/Statistic/MURDERER !!! **
hz dude Offline
#2 Posted : Friday, 5 October 2007 7:27:20 AM(UTC)
hz dude
BUZ does your VN run on gas
if so dont worry about 13 and 45 gas
will muck with these ones had the same prob
on my series 2
its beer oclock
Edited by user Friday, 5 October 2007 7:28:07 AM(UTC)  | Reason: Not specified
hz dude Offline
#3 Posted : Friday, 5 October 2007 7:27:20 AM(UTC)
hz dude
on my series 2
it's beer o'clock
Buz Offline
#4 Posted : Friday, 5 October 2007 9:47:45 AM(UTC)
Buz
hz dude,
No its not on gas unfortunately, but thanks for your input.
No offence, but youre a bastard. ( In the nicest way )
You remind me of how much I miss my old Antelope 308 HZ wagon.
They were good times.
Cheers, Buz.
** Dont drive like a d
Buz Offline
#5 Posted : Friday, 5 October 2007 9:47:45 AM(UTC)
Buz
hz dude,
No it's not on gas unfortunately, but thanks for your input.
No offence, but you're a bastard. ( In the nicest way )
Cheers, Buz.
** Don't drive like
Buz Offline
#6 Posted : Friday, 5 October 2007 10:11:38 AM(UTC)
Buz
P.S.
Three days after she was rebuilt, some @$#%& prick stole her, thrashed her guts out, put a brick on the go pedal and wrapped her around a tree !!!
Such a huge F*n waste :(
Buz Offline
#7 Posted : Friday, 5 October 2007 10:11:38 AM(UTC)
Buz
P.S.
** Dont drive like a dickhead/Statistic/MURDERER !!! **
ED57FE Offline
#8 Posted : Friday, 5 October 2007 5:49:22 PM(UTC)
ED57FE
your sniffer (O2 sensor) is screwed into your exhaust manifold.
you will see a lead and at the end of it a 7/8" fitting... unscrew this to remove it, it's one piece.
your CTS is plumbed into your coolant passage check near your thermostat. I haven
ED57FE Offline
#9 Posted : Friday, 5 October 2007 5:49:22 PM(UTC)
ED57FE
you will see a lead and at the end of it a 7/8" fitting... unscrew this to remove it, its one piece.
your CTS is plumbed into your coolant passage check near your thermostat. I havent
Guest (6)
