#1 Posted : Thursday, 11 October 2007 9:26:53 PM(UTC)
i have a 4dr hq think gts but not sure if its a mokup does anyi no if it is? here r some numbers
trim 1864-38x
paint 567-15331
thanks in advace.
JBM Offline
#2 Posted : Friday, 12 October 2007 1:40:41 AM(UTC)
JBM
1864 is Covert Metallic.
38X is Doeskin and Chestnut Vinyl.
Post the Model No or the VIN (skinny plate) if you want to check if GTS.
James
You only have to be in front at the end of the ra
#3 Posted : Friday, 12 October 2007 1:53:54 AM(UTC)
yeah hi jbm here is the model no
hq80469
11-73 build date
thanks in advance.
JBM Offline
#4 Posted : Friday, 12 October 2007 2:59:24 AM(UTC)
JBM
HQ80469 is a Kingswood V8 Sedan which is what the GTS 4 door was based on and should have option XV4.
For late 73 HQ GTS the VIN should be 8Q69(R, T or U)D.....Q.
Also check the tyre placard as 14 x 6 Wheels were standard on GTS ie, no other wheel size
#5 Posted : Friday, 12 October 2007 3:13:19 AM(UTC)
yeah jbm doesnt the trim code tell ya if its gts?on the skinny plate it has 8q69 rdj if that helps
build in melb.
thanks in advance.
#6 Posted : Friday, 12 October 2007 6:31:37 AM(UTC)
8Q69 is HQ GTS
#7 Posted : Friday, 12 October 2007 7:40:48 AM(UTC)
monaro202 u shore?what does rdj stand 4?
thanks in advance.
Munromad2004 Offline
#8 Posted : Friday, 12 October 2007 8:26:04 AM(UTC)
Munromad2004
It is a GTS.
Early HQ GTS sedans only have the Kingswood model code (80469) and can only be identified by the trim code (W, X, Y or Z)
Later ones started using the 8Q69 designation.
Yours is a GTS.
Mr.Jones Offline
#9 Posted : Friday, 12 October 2007 6:21:57 PM(UTC)
Mr.Jones
tom the 5th letter is the engine code r = 253 t = 308 u = 350, d is year follows U.S. where a model year begins on 1st Sept and the j should be followed by a 3 or 4 to designate the plant which in this case is dandenong H1-4 is Brisbane H5-9 is Sydney J
Voltaire
#10 Posted : Friday, 12 October 2007 7:35:35 PM(UTC)
Mr.Jones thanks 4 that.hey what tells ya its a gts then is it the trim code ifso what letter should it be???and does d stand for 3?
thanks in advance.
JBM Offline
#11 Posted : Saturday, 13 October 2007 12:30:18 AM(UTC)
JBM
As posted above the second letter of the VIN is the trim code, Q=GTS, S=Statesman, T=Caprice, P=Premier or LS, N=Kingswood and M=Belmont. D is the model year for Sep 1 73 to 31 Aug 74, I have a August 74 car and has the D year code, this is only for the n
#12 Posted : Saturday, 13 October 2007 5:17:10 AM(UTC)
Munromad2004
No the second letter of the VIN is not the trim code. It designates the luxury level.
The trim code is what gives it away as being a GTS.
The trim codes of W, X, Y or Z is only used on the GTS.
The vehicle is a GTS.
What is all the confusio
JBM Offline
#13 Posted : Sunday, 14 October 2007 11:27:56 PM(UTC)
JBM
I use the term "Trim" as most people understand that a Kingswood has better or different trim than a Belmont etc. I hope this clarifies the situation. There are other items other than trim or luxury that are different between say a Belmont and a Statesman
