have just bought a hg panel van with drum brakes all round & want to convert to disc front. what parts do i need to change besides hubs,calipers,booster & master cylinder ?
all help appreciated thanks in advance
Hi jayHK69.
You need 2 complete front disc brake assemblies, including hubs, rotors, calipers, pads & stub axles along with the vacuum booster, including brackets, vacuum hose & fittings as well as longer brake pipes. You also need the smaller (9/16") |
thanks dr terry, your input is always appreciated. i have a hk front disc set up can i put this into the hg ? are there any differences i should be aware of ? also can i put a hq 10 bolt diff into a hk ? i imagine i would have to change some brackets et
Hi jayHK69.
If you want HQ stud pattern up front, then fit HQ type brakes. It is not easy to change the HK/T/G front hubs to HQ stud pattern.
The rear end is close in width, but you will need to change the mount brackets etc.
Dr Terry. |
dr terry, could i get a blank hk-t-g hubs a have them drilled to hq pattern ?
thanks
Have sold a few 10 bolt commodore sals. to guys with the intension of modifing for HKTG. simular width?
A1 Bogan. |
As Terry says its heaps easier to fit HQ-WB discs and calipers. Just swap them side to side and use the HG steering arms, and use a HT/HG booster and HQ master cylinder with disc brake HK-HG brake lines. For the back unless you want a stronger diff just |
As Terry says it's heaps easier to fit HQ-WB discs and calipers. Just swap them side to side and use the HG steering arms, and use a HT/HG booster and HQ master cylinder with disc brake HK-HG brake lines. For the back unless you want a stronger diff just |
thanks byron, i`m actually looking at a stronger rear end as i`m putting a fairly warm 350 into the hk. also hq pattern opens up a lot of options for new wheels thanks
If you can find an original HK-HG 10 or 12 bolt and not have to pay mega bucks for it use it. Parts are available new from the US (except axles) for the centre whereas HQ-VK 10-bolt stuff is getting harder to get. I'd actually recommend a VN-VS Borg Warne |
If you can find an original HK-HG 10 or 12 bolt and not have to pay mega bucks for it use it. Parts are available new from the US (except axles) for the centre whereas HQ-VK 10-bolt stuff is getting harder to get. Id actually recommend a VN-VS Borg Warner |
Hi Dr Terry and Byron
I just wanted to send a quick message to let you know that Jayson was rushed to hospital last wednesday. He has cystic fibrosis and had a very acute attack from pancreatitis.
He is slowly on the mend and hopefully should be hom
Hope all is well. I dont think anyone here was thinking him rude. Wish him well for us.
Byron
Hope all is well. I don't think anyone here was thinking him rude. Wish him well for us.
Byron
thanks < |
Thankyou byron for the good wishes and understanding. I will certainly pass them on.
Jayson has improved a great deal, definately on the mend, complaining of being hungry, such a good sign
once again many thanks Deb
Jayson i have recently done my HK you are welcome to have a look if it helps im about 30 mins from parra.
thanks for the offer hm69hk, i think i`ve got it sorted & the wife has just bought a hg panelvan that we want on the road by xmas so my hk prem is on hold for a while
