jayHK69 Offline
#1 Posted : Tuesday, 16 October 2007 12:55:15 AM(UTC)
jayHK69
have just bought a hg panel van with drum brakes all round & want to convert to disc front.
what parts do i need to change besides hubs,calipers,booster & master cylinder ?
all help appreciated
thanks in advance
Dr Terry Online
#2 Posted : Tuesday, 16 October 2007 1:45:15 AM(UTC)
Hi jayHK69.
You need 2 complete front disc brake assemblies, including hubs, rotors, calipers, pads & stub axles along with the vacuum booster, including brackets, vacuum hose & fittings as well as longer brake pipes. You also need the smaller (9/16")
jayHK69 Offline
#3 Posted : Tuesday, 16 October 2007 7:00:35 PM(UTC)
jayHK69
thanks dr terry, your input is always appreciated.
i have a hk front disc set up can i put this into the hg ? are there any differences i should be aware of ?
also can i put a hq 10 bolt diff into a hk ? i imagine i would have to change some brackets et
Dr Terry Online
#4 Posted : Tuesday, 16 October 2007 8:21:20 PM(UTC)
Hi jayHK69.
If you want HQ stud pattern up front, then fit HQ type brakes. It is not easy to change the HK/T/G front hubs to HQ stud pattern.
The rear end is close in width, but you will need to change the mount brackets etc.
Dr Terry.
jayHK69 Offline
#5 Posted : Tuesday, 16 October 2007 9:09:04 PM(UTC)
jayHK69
dr terry, could i get a blank hk-t-g hubs a have them drilled to hq pattern ?
thanks
adam PERTH Offline
#6 Posted : Tuesday, 16 October 2007 9:45:36 PM(UTC)
adam PERTH
Have sold a few 10 bolt commodore sals. to guys with the intension of modifing for HKTG.
simular width?
A1 Bogan.
#7 Posted : Tuesday, 16 October 2007 10:17:50 PM(UTC)
As Terry says its heaps easier to fit HQ-WB discs and calipers. Just swap them side to side and use the HG steering arms, and use a HT/HG booster and HQ master cylinder with disc brake HK-HG brake lines.
For the back unless you want a stronger diff just
#8 Posted : Tuesday, 16 October 2007 10:17:50 PM(UTC)
As Terry says it's heaps easier to fit HQ-WB discs and calipers. Just swap them side to side and use the HG steering arms, and use a HT/HG booster and HQ master cylinder with disc brake HK-HG brake lines.
jayHK69 Offline
#9 Posted : Wednesday, 17 October 2007 7:21:34 PM(UTC)
jayHK69
thanks byron, i`m actually looking at a stronger rear end as i`m putting a fairly warm 350 into the hk. also hq pattern opens up a lot of options for new wheels
thanks
#10 Posted : Wednesday, 17 October 2007 10:15:00 PM(UTC)
If you can find an original HK-HG 10 or 12 bolt and not have to pay mega bucks for it use it. Parts are available new from the US (except axles) for the centre whereas HQ-VK 10-bolt stuff is getting harder to get. I'd actually recommend a VN-VS Borg Warne
#11 Posted : Wednesday, 17 October 2007 10:15:00 PM(UTC)
If you can find an original HK-HG 10 or 12 bolt and not have to pay mega bucks for it use it. Parts are available new from the US (except axles) for the centre whereas HQ-VK 10-bolt stuff is getting harder to get. Id actually recommend a VN-VS Borg Warner
#12 Posted : Sunday, 21 October 2007 7:17:12 AM(UTC)
Hi Dr Terry and Byron
I just wanted to send a quick message to let you know that Jayson was rushed to hospital last wednesday. He has cystic fibrosis and had a very acute attack from pancreatitis.
He is slowly on the mend and hopefully should be hom
#13 Posted : Sunday, 21 October 2007 6:55:26 PM(UTC)
Hope all is well. I dont think anyone here was thinking him rude. Wish him well for us.
Byron
#14 Posted : Sunday, 21 October 2007 6:55:26 PM(UTC)
Hope all is well. I don't think anyone here was thinking him rude. Wish him well for us.
Byron
Dr Terry Online
#15 Posted : Sunday, 21 October 2007 8:46:05 PM(UTC)
thanks
#16 Posted : Sunday, 21 October 2007 9:35:11 PM(UTC)
Thankyou byron for the good wishes and understanding. I will certainly pass them on.
Jayson has improved a great deal, definately on the mend, complaining of being hungry, such a good sign
once again many thanks
Deb
hm69hk Offline
#17 Posted : Thursday, 25 October 2007 12:32:15 AM(UTC)
hm69hk
Jayson i have recently done my HK you are welcome to have a look if it helps im about 30 mins from parra.
jayHK69 Offline
#18 Posted : Thursday, 25 October 2007 10:04:24 AM(UTC)
jayHK69
thanks for the offer hm69hk, i think i`ve got it sorted & the wife has just bought a hg panelvan that we want on the road by xmas so my hk prem is on hold for a while
