adam PERTH Offline
#1 Posted : Tuesday, 16 October 2007 7:04:33 AM(UTC)
adam PERTH
what are the telltail signs?
A1 Bogan.
#2 Posted : Tuesday, 16 October 2007 7:52:50 AM(UTC)
No mounts for a shifter on the extension housing, similar to the difference between an aussie 3spd and 4spd. In fact the Holden specced Saginaw used a 3spd Saginaw extension housing (In HK-HG the shifter was floor/crossmember mounted).
________________
#3 Posted : Tuesday, 16 October 2007 10:28:37 AM(UTC)
The original hk parts catalogue shows a picture of the extension housing with what appears to be the 3 mounting holes for a shifter. The hk series supplement definitely shows pictures with the mounting holes. Same in the ellery workshop manual
Would thes
#4 Posted : Tuesday, 16 October 2007 4:01:10 PM(UTC)
The pictures in the parts catalogue are definitely not of a HK-HG Saginaw. I think the original Scientific Publications (later Gregorys) HK V8 manual has a GTS327 right throught it being pulled apart. The picture on the front is HK.
___________________
