farrblake Offline
#1 Posted : Sunday, 21 October 2007 1:14:06 AM(UTC)
farrblake
Hi All
Drove my car today for the first time after changing engines and the problem is that it really revs out before the transmission changes from 1st to 2nd, around the 70km mark and then from 2nd to 3rd, around the 110km mark, and was wondering why it is doing this as it was fine before the engine change. Thought it might be not enough tranny fluid but dipstick is showing full. Any thoughts as to what the problem may be, or have i just forgot to hook something back up.
Cheers Shane
#2 Posted : Sunday, 21 October 2007 3:39:13 AM(UTC)
Hi Shane.
Make sure you have the modulator connected to a good vacuum source, preferably directly from the inlet manifold itself.
If you already have a vacuum line connected, check to see its not blocked by pulling the hose off at the modulator end,
#3 Posted : Sunday, 21 October 2007 3:39:13 AM(UTC)
Hi Shane.
If you already have a vacuum line connected, check to see it's not blocked by pulling the hose off at the modulator end
farrblake Offline
#4 Posted : Sunday, 21 October 2007 4:14:27 AM(UTC)
farrblake
Thanks Dr Terry
I have the vacuum hooked up but I have it going into the base of the carby, would that matter or is it best into the manifold
Cheers Shane
jabba Offline
#5 Posted : Tuesday, 23 October 2007 7:39:38 PM(UTC)
jabba
Another wee trick is to check the trans fluid hot with engine running. I got caught out checking it engine off, always heaps (overfull). Then mate pointed out need to have engine running and -Bingo- was only half full. Topped up, and changes much smoot
#6 Posted : Tuesday, 23 October 2007 9:00:25 PM(UTC)
probably the vacuum line Get under the car and on the drivers side of the trans there will be a black hose going into the drivers side of the trans make sure its connected properly if it is follow the hose up and make sure it is not cracked or split , any
farrblake Offline
#7 Posted : Thursday, 25 October 2007 2:36:55 AM(UTC)
farrblake
Hi Guys Thanks for all your input, Changed vacuum from base of carby to the manifold on Sunday and it works a treat now.
Cheers Shane
