tony_vc Offline
#1 Posted : Monday, 22 October 2007 6:03:35 AM(UTC)
tony_vc
ey boys...just wopndering wat to do to a blue 202 to make it rip a burnout nd yer stuff like that...nd have a bitta fun in easter nats 2008
thanx
#2 Posted : Monday, 22 October 2007 6:45:10 AM(UTC)
Probably the cheapest way is to buy a complete rusty 308 auto VC-VK Commodore for $750 and put the motor, box and diff into the VC. Apart from that, making a VC 202 go hard enough to pull an effective burnout won't be easy or cheap. With really skinny tyr
#3 Posted : Monday, 22 October 2007 6:45:10 AM(UTC)
Probably the cheapest way is to buy a complete rusty 308 auto VC-VK Commodore for $750 and put the motor, box and diff into the VC. Apart from that, making a VC 202 go hard enough to pull an effective burnout wont be easy or cheap. With really skinny tyre
witcheshollow racing team Offline
#4 Posted : Monday, 22 October 2007 7:15:38 AM(UTC)
My mate Vincy had a $500 VH 2.8lt philipeno 5sp and caned its ass off doig burnouts(1st gear only) on standard rims at Sapphire Speedway where I set up and ran the burnout comps. It wasnt as compeditave as the big shows but none the less he pulled some wi
"Such is life"
#5 Posted : Monday, 22 October 2007 4:10:45 PM(UTC)
The other problem is if it's your daily driver, the old "banjo in disguise" diff won't last too long, and it's not as simple to fix as a banjo either. A Trimatic with external cooler should handle burnouts behind a 6cyl. But still I can't see the old blue
#6 Posted : Monday, 22 October 2007 4:10:45 PM(UTC)
The other problem is if its your daily driver, the old "banjo in disguise" diff wont last too long, and its not as simple to fix as a banjo either. A Trimatic with external cooler should handle burnouts behind a 6cyl. But still I cant see the old blue 202
peter_flane Offline
#7 Posted : Tuesday, 23 October 2007 5:30:34 AM(UTC)
peter_flane
A proper burnout pad is pretty brutal on a lot of cars. It is so caked with rubber, it makes it real sticky. Thin small old tyres are your best chance.
#8 Posted : Tuesday, 23 October 2007 7:21:09 AM(UTC)
Byrons right about the banjo but the first thing that usualy goes are radiator hoses and caps before a box or diff.
Peter smol is half right never use old tires as they go hard and produce little smoke and squeel real bad as the 6 doesnt have enough grun
"Such is life"
peter_flane Offline
#9 Posted : Tuesday, 23 October 2007 9:00:35 AM(UTC)
peter_flane
Very good info. I understand what you say about the hard old tyres squealing, I have seen that before. Last burnout comp I did with my 202 (supercharged) I bought brand new crossply cord light truck tyres with no steel belts. I had it going for a few minu
#10 Posted : Wednesday, 24 October 2007 5:02:04 AM(UTC)
light truck tires are common place on a lot of the V8s as they produce good smoke and the 8s have the grunt to spin them so your 202 must have had plenty of go in it with the supercharger. Most people dont relise that one burnout is equal to 12 months of
"Such is life"
#11 Posted : Wednesday, 24 October 2007 5:02:04 AM(UTC)
light truck tires are common place on a lot of the V8's as they produce good smoke and the 8's have the grunt to spin them so your 202 must have had plenty of go in it with the supercharger. Most people dont relise that one burnout is equal to 12 months o
"Such is life"
peter_flane Offline
#12 Posted : Wednesday, 24 October 2007 6:20:02 AM(UTC)
peter_flane
The 202 had 583Nm of torque in second gear on the dyno.
Guest (6)
