leotard Offline
#1 Posted : Monday, 22 October 2007 8:17:14 PM(UTC)
leotard
hi just wondering if the P,S unit for a V8 will fit a 202 if you use a 6cyl bracket & when I say will they interchange I mean apart from the bracket no other mods needed. Thanks for your advice & help in advance see ya
#2 Posted : Monday, 22 October 2007 10:09:34 PM(UTC)
Was thanked: 601 time(s) in 568 post(s)
100% correct. All you need is the 6cyl bracket, the stud in the rear of the pump, the stay that goes from the stud in the pump back to the engine mount, the pulley and screws, drive belt and lastly the spacers (between the pump and bracket, and between th
#3 Posted : Tuesday, 23 October 2007 4:57:20 AM(UTC)
be warned the late HZ/WB/commie set ups are metric, I have a full exploded view of the set up at oldholden, it even includes the spacer measurments, if you need it I can post link or photo here...
#4 Posted : Tuesday, 23 October 2007 6:57:01 AM(UTC)
thanks for both your time & help & yes i would like the link thanks monaro. Also if i could get a ph no for classicozwreck from you Byron that would be great, cause I can say that after driving this old q for the past 2 yrs Im over the whole lugging the s
#5 Posted : Tuesday, 23 October 2007 6:57:01 AM(UTC)
thanks for both your time & help & yes i would like the link thanks monaro. Also if i could get a ph no for classicozwreck from you Byron that would be great, cause I can say that after driving this old q for the past 2 yrs I'm over the whole lugging the
#6 Posted : Tuesday, 23 October 2007 7:37:41 PM(UTC)
http://gallery.oldholden.com/MONARO_MAD
Have a look around, copy what you want need & with the diagrams it is always a good idea to print them out & laminate them, it makes them last longer & very handy to have when your hands are covered in crap & you
#7 Posted : Tuesday, 23 October 2007 10:19:22 PM(UTC)
Nothing that matters is metric. The engines are still imperial and thats what matters.
#8 Posted : Tuesday, 23 October 2007 10:19:22 PM(UTC)
Nothing that matters is metric. The engines are still imperial and that's what matters.
BlaDe Offline
#9 Posted : Wednesday, 24 October 2007 1:37:09 AM(UTC)
BlaDe
I thought it was just WB that was metric as they use the tear drop style and the first few commos ust the long neck type which is imperial http://www.australianpow.../ex_holden_kingswood.asp
Blade
#10 Posted : Wednesday, 24 October 2007 1:41:01 AM(UTC)
the steering arms are the ones on the hq the short shaft from the column to the box is also different on power steered cars thats what i was told anyway power steering has made all the differenceto my hq cheers
#11 Posted : Wednesday, 24 October 2007 2:48:47 AM(UTC)
#12 Posted : Wednesday, 24 October 2007 2:48:47 AM(UTC)
#13 Posted : Wednesday, 24 October 2007 5:46:39 AM(UTC)
ClassicOzWreck - 02 49598999.
jabba Offline
#14 Posted : Wednesday, 24 October 2007 3:48:24 PM(UTC)
jabba
The shaft from the column to the steering box is the same on PS and non-PS steering boxes. On non-PS, the shaft from the flexible coupling into the steering box is longer, where the PS box hasa short shaft and the power bits on top.
The actual box its
Guest (8)
This page was generated in 0.082 seconds.
