tenticles Offline
#1 Posted : Tuesday, 30 October 2007 4:29:32 PM(UTC)
tenticles
assuming that a points dizzy is in good nick, and i do my gap and clean' maintainence every few thousand k's, what are the advantages of replacing the distributor with an electronic one in my 253 HQ ute?
and is the factory offering as good as the aftermarket models
thanx in advance, johnny
yes sonny, it's an HQ ute
ozjason Offline
#2 Posted : Tuesday, 30 October 2007 6:38:56 PM(UTC)
ozjason
You don't *need* to do your gap and clean maintenance. Never set another gap, and our spark plugs stay cleaner longer (better spark with electronic).
Slightly better performance over the entire rev range.
It's a more reliable unit, less chance you'
ozjason Offline
#3 Posted : Tuesday, 30 October 2007 6:38:56 PM(UTC)
ozjason
You dont *need* to do your gap and clean maintenance. Never set another gap, and our spark plugs stay cleaner longer (better spark with electronic).
Its a more reliable unit, less chance youll
keithholden Offline
#4 Posted : Tuesday, 30 October 2007 8:25:42 PM(UTC)
keithholden
Electronic is good . Only bad thing I would say is that when I put the dizzy in I didnt know how to staticlly time it as there was no spark at the points cause there isnt any.
Must be another way to do this. I only needed to statically time it to start
christoss Offline
#5 Posted : Wednesday, 31 October 2007 7:17:26 AM(UTC)
christoss
With engine on TDC #1 comp stroke rotor buton should have just past #1 h/t lead post. only by a fraction. this should be good enough to get running.Assuming dizzy phasing is correct.If you set engine to 22 degrees BTDC the rotor button should be nearly pe
Guest (5)
