2 Pages<12
#21 Posted : Wednesday, 31 October 2007 10:12:54 PM(UTC)
Except they probably wont cool an iron headed 350 Th400 with a 3 row radiator.
#22 Posted : Wednesday, 31 October 2007 10:12:54 PM(UTC)
Except they probably won't cool an iron headed 350 Th400 with a 3 row radiator.
keithholden Offline
#23 Posted : Thursday, 1 November 2007 3:51:28 AM(UTC)
keithholden
Ive just trimmed about 7mm off the top point of the flex fan.
I made a template out of an icream container lid and marked them all evenly.
Im now draining my radiator into a bucket to save the antifreeze so I can remove the radiator.
Im going to slot
#24 Posted : Thursday, 1 November 2007 4:49:15 AM(UTC)
The Commodore fan won't work with the HQ-HZ shroud. Not even with a 308. A HQ-HZ with the rounded blades might with the radiator lifted.
If we all had the same (good) taste, who would buy all the
#25 Posted : Thursday, 1 November 2007 4:49:15 AM(UTC)
The Commodore fan wont work with the HQ-HZ shroud. Not even with a 308. A HQ-HZ with the rounded blades might with the radiator lifted.
keithholden Offline
#26 Posted : Thursday, 1 November 2007 6:07:43 AM(UTC)
keithholden
HQ v8 one you mean??
Radiator is out ill try finish it on the weekend as working lots the next few days :(
#27 Posted : Thursday, 1 November 2007 10:42:11 PM(UTC)
i use a factory 4 blade fan in my HZ 308. i bolted a fan shroud to the holes in my radiator as it looked at the right height. and my fan also hit. do you guys know where i messed up.
#28 Posted : Thursday, 1 November 2007 11:48:17 PM(UTC)
Using a shroud without using the appropriate viscous fan.
#29 Posted : Saturday, 3 November 2007 6:57:25 AM(UTC)
Originally posted by BlaDe
you could get new au twins off fleabay sent to your door for around $250
antoni Offline
#30 Posted : Saturday, 3 November 2007 10:21:08 AM(UTC)
antoni
Hi I HAVE USED FORD TWIN FANS, WORK VERY GOOD ON C10 350/T400
GOOD IN CITY, TURN OFF ON AT THE LIGHTS, BEEN ON FOR 3 YEARS NOW.
THANKS TONY
#31 Posted : Sunday, 4 November 2007 4:09:36 AM(UTC)
Problem is C10's have a huge radiator, but the HQ style one is pretty limited, even as a 5 row. The best bet in one of these is to convert to WB and run a WB 4-row with factory shroud.
If we all
#32 Posted : Sunday, 4 November 2007 4:09:36 AM(UTC)
Problem is C10s have a huge radiator, but the HQ style one is pretty limited, even as a 5 row. The best bet in one of these is to convert to WB and run a WB 4-row with factory shroud.
If we all h
keithholden Offline
#33 Posted : Monday, 5 November 2007 4:50:53 AM(UTC)
keithholden
I drilled some new holes in my fan shroud and moved it up.
Its not hitting , but is slightly off centre.
I have yet to close the bonnet. I just remembered :)
Hope it will do for the mean time.
I wont know till I run the car and see how hot it gets.
rb30EJvan Offline
#34 Posted : Tuesday, 6 November 2007 7:26:33 AM(UTC)
rb30EJvan
Hi i to have had engine fan problems and the best answer is to fit a electric thermo fan for the time you spend trying to modifyfans and shroulds in a couple of hours you can fit a far better fan plus you will get a small hp gain and it makes your engine
Guest (8)
2 Pages<12
This page was generated in 0.066 seconds.
