#1 Posted : Thursday, 1 November 2007 1:59:02 AM(UTC)
I was needing some help with engine mounts for a 283 chev motor out of a 69 corvette. i was wondering if the mounts on the 283 block are the same as the 350?? in saying that do all carbied 350s have the same mount positions??
adam PERTH Offline
#2 Posted : Thursday, 1 November 2007 2:53:45 AM(UTC)
adam PERTH
AFAIK, all SBC Gen 1 motors have the same engine mounts from 1959 onwards.
Pre - 1959, they mount simular to the old 138 grey motor design.
A1 Bogan.
#3 Posted : Thursday, 1 November 2007 4:50:40 AM(UTC)
Basically Adam is correct. There are different mount adapters, but the mounting positions on the block are the same.
adam PERTH Offline
#4 Posted : Thursday, 1 November 2007 4:59:51 AM(UTC)
adam PERTH
R u 100% sure?
i thought the early 1955 - 59 block didnt have the 3 holes on either side to mount, i thought they were blank?
Why do these early blocks command such a high price if they mount the same??
A1 Bogan.
adam PERTH Offline
#5 Posted : Thursday, 1 November 2007 4:59:51 AM(UTC)
adam PERTH
R u 100% sure?
i thought the early 1955 - 59 block didn't have the 3 holes on either side to mount, i thought they were blank?
A1 Bogan.
#6 Posted : Thursday, 1 November 2007 7:13:19 AM(UTC)
I'm 100% sure you are correct. Early blocks had no side mounts. All later blocks are the same, just the mounting adapters differed.
If we all had the same (good) taste, who would buy all the Ford
#7 Posted : Thursday, 1 November 2007 7:13:19 AM(UTC)
Im 100% sure you are correct. Early blocks had no side mounts. All later blocks are the same, just the mounting adapters differed.
If we all had the same (good) taste, who would buy all the Fords
