i was parked at a car show with my van and was told my yellow needle dash is wrong for my model van. it should be a blue needle dash. i have never heard of a blue needle dash before.
only white up to hz then yellow, the only weird coloured one is out of a cop car speedo.
cop car speedo? never heard of them? what are they? |
they are only available in police cars, they have fine lines between the normal range of say 40-45-50 etc. cop speedo will have 50-51-52-53-54-55-the numbers are not printed as such but lines representing them are on the speedo, usually around the 60 and
well there ya go! never heard of them..... you have a pic out of interest? |
I have put one of the cop speedos in my HJ. Not a bad looking speedo.... Heres a link to a picture of it. http://holdenpaedia.oldh...Z_Dash_Conversion_18.jpgCheers, Hairy-Dude.
I have put one of the cop speedo's in my HJ. Not a bad looking speedo.... Here's a link to a picture of it. http://holdenpaedia.oldh...Z_Dash_Conversion_18.jpgCheers, Hairy-Dude.
when I put my Q over the pits I had swapped the tacho and speedo around and had to swap them back to the right sides before the inspectors would pass it they reckoned the speedo could not be read clearly through the steering wheel and was not original pla
Hey fellas, just while we are on GTS dashes, Has anyone noticed the difference between the HZ and WB yellow needle GTS dash??? from what i can tell, the empty on the fuel and alt on the HZs was red, while the WB was all yellow. any comments?
A1 Bog |
Hey fellas, just while we are on GTS dashes, Has anyone noticed the difference between the HZ and WB yellow needle GTS dash??? from what i can tell, the empty on the fuel and alt on the HZ's was red, while the WB was all yellow. any comments?
A1 Bo |
was there a WB GTS dash???
Rare Spares Perth (REX SPARES) Representative. If you have an enquiry, feel free to message me. To shop online directly from Rare Spares
yep, the GTS dash was optional on all models and from what I know and have seen, the dahses are the same - the red warning sectors were always red irrespective of HZ or WB, my guess is the ones you saw on the WB were tired and faded. cheers frank
An addendum! Firstly, its dashes, not dahses, and secondly, "on all models" refers to the WB ute and van, not the WB Statesmans ... cheers frank
I disagree with the faded theory. My factory 308, M20 2 seater 1984 WB kingswood ute is 100% orig, and the Dash is not faded, (1 owner , 238,000 km). ALL of the WB's kingswoods with GTS dashes that i have wrecked / seen have been all yellow, the o Edited by user Thursday, 8 November 2007 12:18:33 AM(UTC)
| Reason: Not specified |
I disagree with the faded theory. My factory 308, M20 2 seater 1984 WB kingswood ute is 100% orig, and the Dash is not faded, (1 owner , 238,000 km). ALL of the WBs kingswoods with GTS dashes that i have wrecked / seen have been all yellow, the on Edited by user Thursday, 8 November 2007 12:18:33 AM(UTC)
Hi adam.
Im not quite sure what you are saying.
Do you mean that late WB GTS-type yellow needle instruments also have yellow warning sectors. By that I mean the lowest point on the scale, the vertical line, is it red, yellow or red faded to white.
Hi adam.
I'm not quite sure what you are saying.
Do you mean that late WB GTS-type yellow needle instruments also have yellow warning sectors. By that I mean the lowest point on the scale, the vertical line, is it red, yellow or red faded to white. |
yes, all warning selectors are Yellow. i can take photo, but i don't know how to load them.
A1 Bogan. |
yes, all warning selectors are Yellow. i can take photo, but i dont know how to load them.
A1 Bogan. |
