boom Offline
#1 Posted : Wednesday, 7 November 2007 8:11:33 AM(UTC)
boom
what's the best manifold to suit a quaddie for a 202? also can i get adaptor plates from redline, and would spacers give much gains in performance?
If it doesn’t burn fossil fuels, it’s not a sport.
#2 Posted : Wednesday, 7 November 2007 9:17:25 AM(UTC)
Boom On my 202 reds I have always had Cain manifolds. Which are duel pattern manifolds (drilled to suit spreadbore and squarebore) So the Qjet just bolts straight on. There is a pic here http://gallery.oldholden...Our+HR/P5120013.jpg.html
#3 Posted : Wednesday, 7 November 2007 4:03:22 PM(UTC)
John Cain no longer makes them. Hardiman (Redline) have most of his moulds and sell the manifolds.
adam PERTH Offline
#4 Posted : Wednesday, 7 November 2007 11:22:34 PM(UTC)
adam PERTH
You could try and get a 4 barrel SQ bore holden 6 inlet, you should get one if you advertise....
then put a $25 adaptor for the spreadbore on to fit the Q-Jet.
A1 Bogan.
boom Offline
#5 Posted : Thursday, 8 November 2007 12:28:06 AM(UTC)
boom
cool, i need one for the 12 port head, are they availible?
#6 Posted : Thursday, 8 November 2007 6:12:27 AM(UTC)
No. Only for Red. There is little point using a single carb on a 12-port head, and little market so no-one ever really bothered.
boom Offline
#7 Posted : Friday, 9 November 2007 2:08:24 AM(UTC)
boom
sooo, can i get an adaptor plate for my current manifold? (stock black)
#8 Posted : Friday, 9 November 2007 4:10:47 AM(UTC)
Yes, but it's a dreadful manifold. I think you can buy a 2 barrel adapter but a 4barrel one will be a waste of time as the stock manifold is only a 2-barrel. You'd be better off putting a red head on it and running a Redline manifold.
_________________
#9 Posted : Friday, 9 November 2007 4:10:47 AM(UTC)
Yes, but its a dreadful manifold. I think you can buy a 2 barrel adapter but a 4barrel one will be a waste of time as the stock manifold is only a 2-barrel. Youd be better off putting a red head on it and running a Redline manifold.
___________________
boom Offline
#10 Posted : Friday, 9 November 2007 8:01:10 AM(UTC)
boom
Are you joking?
adam PERTH Offline
#11 Posted : Friday, 9 November 2007 7:44:57 PM(UTC)
adam PERTH
compare 500 holley...they are 2 barrel.
A1 Bogan.
boom Offline
#12 Posted : Friday, 9 November 2007 9:40:41 PM(UTC)
boom
holleys are crap compared to rochesters. 2barrells anyway.
#13 Posted : Saturday, 10 November 2007 4:53:22 AM(UTC)
Originally posted by boom
Are you joking?
boom Offline
#14 Posted : Saturday, 10 November 2007 6:26:26 AM(UTC)
boom
what if i cut off the 2bbl flange and welded/bolted on a 4bbl rochester flange from a 253/308. would that work?
#15 Posted : Saturday, 10 November 2007 7:01:51 PM(UTC)
Yes, but the manifold is still a piece of cr*p. Have a look inside at the path the centre cylinder's fuel/air mix has to take. If you're going to start cutting/welding cut the engine flanges off a Redline 4BBL manifold and weld the VK ones on and die grin
#16 Posted : Saturday, 10 November 2007 7:01:51 PM(UTC)
Yes, but the manifold is still a piece of cr*p. Have a look inside at the path the centre cylinders fuel/air mix has to take. If youre going to start cutting/welding cut the engine flanges off a Redline 4BBL manifold and weld the VK ones on and die grind
boom Offline
#17 Posted : Saturday, 10 November 2007 7:43:52 PM(UTC)
boom
byron you've done it again! is the redline manifold the best choice?
boom Offline
#18 Posted : Saturday, 10 November 2007 7:43:52 PM(UTC)
boom
byron youve done it again! is the redline manifold the best choice?
boom Offline
#19 Posted : Saturday, 10 November 2007 7:51:41 PM(UTC)
boom
what about a 12 port redline 2bbl with the 4bbl carb flange welded on? or is it a completely different manifold from 2bbl to 4bbl.
#20 Posted : Saturday, 10 November 2007 8:01:21 PM(UTC)
I don't think anyone makes a 2 barrel one for a blue motor either. In any case the 4barrel manifold looks very different to the 2 barrel one. Look at
http://www.redlineauto.c...DS_TO_SUIT_6_CYL_ENGINES
12-
Guest (13)
