#1 Posted : Wednesday, 7 November 2007 9:53:57 AM(UTC)
hi guys
can't start the car - fuel is pumping up to the carby okay, but no spark from the coil lead (dizzy end) when cranking and holding it 3/16 from the block and no spark from the plug lead either. I've replaced the condensor, dizzy cap, points and set the gap correctly. The coil is also getting very hot. The low tension lead is going from the +ve on the coil to the dizzy. I've tried another coil, still no luck. Its cranking fine but doesn't even seem to want to start ... any ideas? too dark to see what I'm doing now, but will check the points again tomorrow. cheers frank
HQforme Offline
#2 Posted : Wednesday, 7 November 2007 10:05:51 AM(UTC)
HQforme
Maybe it's just lacking juice? The starter, as you well know, robs a shedload of current. If there's just one dodgy spot in the wiring, increased resistance somewhere, maybe there's just not enough current left, even after going through the coil, to provi
"Silly modern cars"
HQforme Offline
#3 Posted : Wednesday, 7 November 2007 10:05:51 AM(UTC)
HQforme
Maybe its just lacking juice? The starter, as you well know, robs a shedload of current. If theres just one dodgy spot in the wiring, increased resistance somewhere, maybe theres just not enough current left, even after going through the coil, to provide
"Silly modern cars"
jabba Offline
#4 Posted : Wednesday, 7 November 2007 4:55:21 PM(UTC)
jabba
+ve on the coil should be your ignition (battery) feed. -ve then goes to dizzy, which breaks the current to earth to make spark. -ve also goes to tach feed.
Coils can also cook themselves. I had an Accel coil which dear friend mr dodgy panelbeater bl
#5 Posted : Wednesday, 7 November 2007 7:17:43 PM(UTC)
hi Jabba
yep, mechanical points ... brand new Bosch set. rotor seems fine too. will get stuck into it later ...
cheers frank
jabba Offline
#6 Posted : Wednesday, 7 November 2007 9:35:41 PM(UTC)
jabba
Troubleshooting steps:-
1/ Disconnect all wires from coil
Run fresh feed from battery to +ve on coil
Clip test lead to -ve on coil, and rest other end on known good earth
Quickly lift earth end - should be a spark. If not, repeat a few times
#7 Posted : Thursday, 8 November 2007 4:08:10 AM(UTC)
hi jabba
thanks for your tips, it was point 3 - insulating washer! All okay now, I appreciate your help,
cheers frank
jabba Offline
#8 Posted : Thursday, 8 November 2007 2:48:43 PM(UTC)
jabba
No probs.
I have battled with old school ignition systems for years. It is probably one of the few systems I can figure out with a degree of certainty.
