#1 Posted : Sunday, 9 September 2007 7:53:28 PM(UTC)
hi, just wondering ...
my 1974 HQ ute has the following info listed on the build plate (plate riveted above the heater)
MODEL HQ80480
ENG. TRANS. M40 RRAXLE GV3
i.e the engine type/option has not been stamped onto plate, it is blank
is this normal, rare or just monday morning hangover stuff?
Munromad2004 Offline
#2 Posted : Sunday, 9 September 2007 10:56:40 PM(UTC)
Munromad2004
Its normal. Not stamped if the standard engine was fitted.
I think the HJs were the first model to have all info stamped regardless.
#3 Posted : Sunday, 9 September 2007 10:56:40 PM(UTC)
Munromad2004
It's normal. Not stamped if the standard engine was fitted.
I think the HJ's were the first model to have all info stamped regardless.
JBM Offline
#4 Posted : Monday, 10 September 2007 8:36:11 AM(UTC)
JBM
The engine fitted can be found from the fifth letter of the VIN, U for 350, T for 308, R for 253, L for 202 D for 173. A 350 wouldnt have a Trimatic behind it though.
James
You only have to be
JBM Offline
#5 Posted : Monday, 10 September 2007 8:36:11 AM(UTC)
JBM
The engine fitted can be found from the fifth letter of the VIN, U for 350, T for 308, R for 253, L for 202 D for 173. A 350 wouldn't have a Trimatic behind it though.
James
You only have to b
Dr Terry Online
#6 Posted : Monday, 10 September 2007 4:42:30 PM(UTC)
tenticles Offline
#7 Posted : Monday, 10 September 2007 5:52:39 PM(UTC)
tenticles
unbelievable info gents, many thanx
so if the engine no. is QR 559XXX, what are the chances of it being the original donk?
any other details that would help needed?
yes sonny, its an HQ ute
yes sonny, it's an HQ ute
tenticles Offline
#8 Posted : Monday, 10 September 2007 5:52:39 PM(UTC)
tenticles
JBM Offline
#9 Posted : Monday, 10 September 2007 6:34:37 PM(UTC)
JBM
Check the date cast code just above the oil pump, will look like 10K4, and compare it to the cars build date. That number is fairly close as around 500,000 HQs were built.
James
You only have
