Hi all.
I have a 308 in my shed but I don't know if it is blue, red or black or what it came out of.
The engine number (found on front right side where head meets the block) 1101908971
I also found numbers just above the water pump 836 or 8E6
Also. How do I know what heads I have? The numbers on the inlet side of the heads are 7292. There are no numbers on the outside of the heads.
regards
Dave
Hi wildshotz
That engine number should read 11QT908971, which is a Red 308 out of an HX Statesman.
The 8E6 date casting is 8th May 1976.
The head casting numbers are under the rocker cover.
Dr Terry |
Number is probably 11QT908971. Cast date should be around November or December 1977 if you have the engine number right - xxQx908971 belongs in a 12/77 or 1/78 HZ. If the number is right its a HZ Statesman block. Will be TH pattern red motor. EGR port in |
Number is probably 11QT908971. Cast date should be around November or December 1977 if you have the engine number right - xxQx908971 belongs in a 12/77 or 1/78 HZ. If the number is right it's a HZ Statesman block. Will be TH pattern red motor. EGR port in |
Hi Guys I have rechecked the numbers. The engine number is 11QT908971 casting date is 9E8 reading it from the front of the engine above the water pump. It's funny, Someone on the old holden site reckons its a 1982 buckskin WB statesman, On this site it
Hi Guys I have rechecked the numbers. The engine number is 11QT908971 casting date is 9E8 reading it from the front of the engine above the water pump. Its funny, Someone on the old holden site reckons its a 1982 buckskin WB statesman, On this site it c
A WB would have a 11WT... number.
James
You only have to be in front at the end of the race. |
quote: Originally posted by wildshotz
Hi Guys I have rechecked the numbers. The engine number is 11QT908971 casting date is 9 |
Thanks guys. That clears things up..
Thanks guy's. That clears things up..
Hi Guys I have a 308 that is in a Rang Rover that I acquired recently to repair and get back on the road. I need to identify the engine so that I can get some parts for it as the motor is not complete. the engine number is 11QT758950 which I see from y
Its a HX block should be a june 1976, I have a sept 76 HX with original motor which is QR790xxx
Yes, HX Statesman engine and heads. Will be a TH pattern block too (suit TH400, TH350, TH700 etc gearbox).
thanks for the information. I can now start looking for parts etc for the right model and vintage. Cheers Ray
