leotard Offline
#1 Posted : Monday, 12 November 2007 2:08:49 AM(UTC)
leotard
hi just wondering if the powersteer of a 6cyl say VB, VC commodore would go onto a HQ ute as in complete changeover you know plug & play type thing. Any help or sugestions would be appreciated thanks muchly Bye
peter_flane Offline
#2 Posted : Monday, 12 November 2007 5:52:14 AM(UTC)
peter_flane
Not a bolt in fit. have a look at www.v6conversions.com.au
peter_flane Offline
#3 Posted : Monday, 12 November 2007 5:52:14 AM(UTC)
peter_flane
Not a 'bolt in' fit. have a look at www.v6conversions.com.au
Mr Void Offline
#4 Posted : Monday, 12 November 2007 9:22:34 PM(UTC)
Mr Void
___________________
Mr Void Offline
#5 Posted : Monday, 12 November 2007 9:22:34 PM(UTC)
Mr Void
___________________
#6 Posted : Monday, 12 November 2007 10:04:45 PM(UTC)
Hi Guys.
Putting a Commodore rack into an HQ-WB would require some serious mods.
Firstly, in a Commodore the rack is mounted behind the front axle centreline, whereas the HQ-WB steering linkage is in front. If you use a Commodore rack in that spot,
#7 Posted : Wednesday, 14 November 2007 5:38:02 AM(UTC)
thanx for the help the only reason i asked the Q was it seems there are far more comms around still to get 1 from to find 1 for a six is a little difficult but i will keep looking and abandon the whole comm idea thanks again.
#8 Posted : Wednesday, 14 November 2007 8:04:14 AM(UTC)
Hi leotard.
You mention 6 cyl a few times.
If youre finding it difficult to find a 6 cyl HQ-WB set-up, then buy the pump & brackets off an early Commodore 6 cyl & then hook it up to a normal HQ-WB box, off a HQ-WB V8 Statesman or similar. Everything
#9 Posted : Wednesday, 14 November 2007 8:04:14 AM(UTC)
Hi leotard.
If you're finding it difficult to find a 6 cyl HQ-WB set-up, then buy the pump & brackets off an early Commodore 6 cyl & then hook it up to a normal HQ-WB box, off a HQ-WB V8 Statesman or similar. Everythin
#10 Posted : Tuesday, 11 December 2007 9:10:47 AM(UTC)
blacks racks in margret river wa do a bolt in rack and pinion set up fully engineered
satanic customs Offline
#11 Posted : Tuesday, 11 December 2007 3:01:50 PM(UTC)
satanic customs
early commodore six cyl power steer not that common to find either
#12 Posted : Tuesday, 11 December 2007 4:09:12 PM(UTC)
Geez guys. I wish HK parts were as "rare" as 6cyl Commodores with steer! And HQ-WB power steering setups!
#13 Posted : Tuesday, 11 December 2007 5:47:03 PM(UTC)
They are fairly common at the wreckers here in Brisbane, how many do you want? You could also use the VK type if you wanted, but might have to have custom pipes made.
A couple ofphone calls to commodore wreckers or specialist holden wreckers should get
#14 Posted : Tuesday, 11 December 2007 10:22:49 PM(UTC)
If you do get the 6cyl setup as Warren says get the spacers for the pump to bracket AND bracket to engine. Plus get the 3x longer bolts for the engine: 1 x thermostat housing, 1 x waterpump and 1 x RH engine mount. Plus the stay between the pump and the e
