#1 Posted : Wednesday, 14 November 2007 2:40:54 AM(UTC)
I got a big problem. i moved me car out of my driveway and changed the back wheels and then when i started it to go it wont move.
It is a 351 xb with c4 and hurst shifter. it goes to select gears and sounds like it is selecting gears but will not move. and the tailshaft is not moving. is my gearbox buggered or something else broken. any ideas???
#2 Posted : Wednesday, 14 November 2007 2:58:09 AM(UTC)
snd when i grab and pull on the gearbox cable i do get movement from the car. any thoughts on how this problem and any temporary fix to get to gearbox shop
6pak Offline
#3 Posted : Wednesday, 14 November 2007 5:02:09 AM(UTC)
6pak
Hi Andrew. It sounds like the shifter cable needs adjusting if it reacts when you mess around with the cable. I recently put a B&M Megashifter on my C4 and had to spend a heap of time mucking around with cable adjustment to get it spot on, it didn't hav
#4 Posted : Thursday, 15 November 2007 2:23:02 AM(UTC)
yeah there is plenty of fluid in there. it seems to move when the revs are high sorta about 4 thousand. ive tryed playing around with the selecter cable. its like its got a high stall converter when it dosnt. yeah i really have no idea
6pak Offline
#5 Posted : Thursday, 15 November 2007 6:50:04 AM(UTC)
6pak
Does it move in reverse or is the result the same in all gears?
#6 Posted : Thursday, 15 November 2007 8:41:08 AM(UTC)
no it dosnt mate. it only moves backwards or forwards a few centermeters when reved. when u change into a gear it feels and sounds like it engages and wants to move but it dosnt. is this what happens when a gearbox ****s itself?? im not sure
.its really
Paul351xb Offline
#7 Posted : Thursday, 15 November 2007 5:01:03 PM(UTC)
Paul351xb
Hmmmmmmmm. Andrew, as long as your driveway isn't on a slope try dropping your tail shaft. If it's the gear box playing up you will be then able to at least roll the car. If it still won't roll with the tail shaft out then the problem will most likely
#8 Posted : Friday, 16 November 2007 2:00:33 AM(UTC)
Have you tried putting the other wheels bsck on and see if it moves, i dont mean to sound like a smart a???, perhaps the newq wheels are not clearing.
6pak Offline
#9 Posted : Friday, 16 November 2007 5:09:13 AM(UTC)
6pak
If Paul and Ron's suggestions don't bear fruit i"m wondering if the problem lies in the valve body. I'm afraid this is pretty much where my VERY limited understanding of auto transmissions hits a wall.
Munromad2004 Offline
#10 Posted : Friday, 16 November 2007 7:47:44 AM(UTC)
Munromad2004
Here's a couple of very basic things to check.
1. Is the handbrake jammed on?
2. If you fitted larger wheels on the back are they binding on anything?
3. When you jacked the rear of the car bit you accidentally damage/crush any brake lines?
If
#11 Posted : Friday, 16 November 2007 10:28:17 AM(UTC)
thanks guys. good to know there is fellas out there who help a fellow ford man out in time of need.
i havnt had time to remove tailshaft yet. i was thinking wouldnt the tailshaft still spin if car in gear and the gearbox was working??
And also if the p
Paul351xb Offline
#12 Posted : Friday, 16 November 2007 8:18:12 PM(UTC)
Paul351xb
Andrew, take the new wheels off and check the calipers.
Put the old wheels on for now and then jack the back wheels up and ( here's the hard bit) put the car in neutral and see if you can spin the wheels freely. If not something is jamming. Get someone
ford_chick Offline
#13 Posted : Saturday, 17 November 2007 1:23:47 AM(UTC)
ford_chick
Andrew, keep us updated on how you go. We have recently purchased an XB coupe (302 with a C4) and we had a similar problem. Got it home moved it backwards and forwards a few times then it just didn't want to move anymore. We had it jammed in neutral thoug
basketcasebear Offline
#14 Posted : Saturday, 17 November 2007 5:45:50 AM(UTC)
basketcasebear
hey andrew, i would jack up the car,,undo the cable from the trans, see if you can select different gears, manually, and if you can, see if you can get neutral,,i had to do this with my conversion, due to bogey job of making new arm for tbar? if you can
DOH!!!
HG-PREM Offline
#15 Posted : Wednesday, 21 November 2007 3:00:49 AM(UTC)
HG-PREM
snapped axle?
This page was generated in 0.150 seconds.
