wals186s Offline
#1 Posted : Wednesday, 14 November 2007 6:38:44 AM(UTC)
wals186s
The wiring harness in the car has a single light tan coloured wire in the engine bay loom. It is just over 1.6 meter long and has a a bullet push on fitting on the end with the clear plastic cover. It looks factory. I cannot find it on any wiring diagram.
Is there a genuine engine bay light that is fitted to the underside of the bonnett?????
Thanks and cheers
Steve
#2 Posted : Wednesday, 14 November 2007 4:40:23 PM(UTC)
1.6 meters would take it to the front of the engine compartment, can only think of heater fan or brake fail switch that were light tan, but neither of these is 1.6m from their harness connections, does it come in the lighting harness or the engine harness
#3 Posted : Friday, 16 November 2007 12:04:37 AM(UTC)
Hi Warren and thanks for your reply and I was hoping you would have a go at this one.
I have asked several people the same question. The harness I am using came out of a factory optioned HG V8 manual wagon with monaro dash. It is the engine harness an
#4 Posted : Friday, 16 November 2007 2:30:24 AM(UTC)
There was an option for under dash light for Government vehicles only, this might be it, but without seeing it I could not say 100%. They were not available on Monaro so i have not 100% researched them. I would have though they were of the park lights but
#5 Posted : Friday, 16 November 2007 10:11:58 PM(UTC)
It is for brake fail light on 71 hgs. It goes on the alloy brake block on inner guard under booster.Change of ADRs in 71.
#6 Posted : Friday, 16 November 2007 10:11:58 PM(UTC)
It is for brake fail light on 71 hg's. It goes on the alloy brake block on inner guard under booster.Change of ADR's in 71.
#7 Posted : Saturday, 17 November 2007 2:10:42 AM(UTC)
Looking agian at your post, the lower second last is for the fan. The one above is blank, and this is where Iwould think the wire might come through.
Warren
wals186s Offline
#8 Posted : Wednesday, 21 November 2007 4:18:16 AM(UTC)
wals186s
Hi Warren, the 2nd top, from the right, as you look from the engine side, is the one for the fan motor, well on this car.
The long wire is comming from the one directly underneath.
Again thanks for you efforts in finding out my problem.
wals186s Offline
#9 Posted : Thursday, 22 November 2007 6:39:16 AM(UTC)
wals186s
Hi Warren, thanks to Paul it is the Pressure switch for the brakes.
thanks and cheers
steve
This page was generated in 0.065 seconds.
