sgo Offline
#1 Posted : Monday, 19 November 2007 5:28:32 AM(UTC)
sgo
Is there any variation in design of stock cast iron 308 exhaust manifolds?
If so, does any particular model have the outlet further forward than any other?
I'm trying to overcome some clearance issues.
#2 Posted : Monday, 19 November 2007 6:55:18 AM(UTC)
There are a few basic types eg HQ, Torana, Commodore. Which side is the problem side?
sgo Offline
#3 Posted : Monday, 19 November 2007 8:22:53 AM(UTC)
sgo
I think I have HQ type, with the outlet pointing to the the rear?
Doesnt work in a 60s Commair Bus!
An outlet pointing straight down would be good.
Is there such a thing?
sgo Offline
#4 Posted : Monday, 19 November 2007 8:22:53 AM(UTC)
sgo
Doesn't work in a 60's Commair Bus!
basketcasebear Offline
#5 Posted : Monday, 19 November 2007 10:52:33 AM(UTC)
basketcasebear
hey sgo,
i have the same prob in my 98 transit,,the drivers side exhaust points down straight, and the pass side points backwards?? [about45 degrees] came out of a vb comm,,
i am going to have to get the exhaust pipe bent to go under the front crossmemb
DOH!!!
#6 Posted : Monday, 19 November 2007 4:06:09 PM(UTC)
I can't remember for sure (would have to look at all the ones in my shed) but one of the Torana ones differs for the same reason, so look at an LH/LX Torana engine bay. Also you might want to investigate block hugger headers. I'm not sure if they are avai
#7 Posted : Monday, 19 November 2007 4:06:09 PM(UTC)
I cant remember for sure (would have to look at all the ones in my shed) but one of the Torana ones differs for the same reason, so look at an LH/LX Torana engine bay. Also you might want to investigate block hugger headers. Im not sure if they are availa
sgo Offline
#8 Posted : Monday, 19 November 2007 11:53:18 PM(UTC)
sgo
Thanks for the tips, good to know there are some variations.
Will check out a few engine bays.
Swapping let to right might help too.
Cheers.
#9 Posted : Tuesday, 20 November 2007 2:57:43 AM(UTC)
WB Statesman is also different than HQ-HZ. Slightly different angle..
