HQ SAND MAN Offline
#1 Posted : Wednesday, 21 November 2007 5:59:10 AM(UTC)
HQ SAND MAN
The van has a 327 Saginaw in it do I keep that combo or should i go back to factory specs ??
#2 Posted : Wednesday, 21 November 2007 6:17:14 AM(UTC)
without the original motor I do not think it would matter about the drive line to much unless you want historic rego,
do the body and decals as per original to keep with the flavour of the car and maybe the interior.
#3 Posted : Thursday, 22 November 2007 3:06:07 AM(UTC)
I guess if you go back to original specs then you could drive around in a gutless Holden V8 powered van..
Or.. Keep the Chev and have power to burn...
adam PERTH Offline
#4 Posted : Thursday, 22 November 2007 3:24:29 AM(UTC)
adam PERTH
i am with you luke!, especially if the van was L32.
Lets get back to basics,
Isnt this what being a petrol head is all about?
A1 Bogan.
adam PERTH Offline
#5 Posted : Thursday, 22 November 2007 3:24:29 AM(UTC)
adam PERTH
Isn't this what being a petrol head is all about?
A1 Bogan.
HQ SAND MAN Offline
#6 Posted : Thursday, 22 November 2007 4:18:42 AM(UTC)
HQ SAND MAN
it was a factory 5.0 M21 ,, so the CHEV is the way yoo go!!!!
monaro mark Offline
#7 Posted : Thursday, 22 November 2007 5:48:21 AM(UTC)
monaro mark
If I were you, I'd find a correct date code and engine prefix 308 for it. It will be worth more in the long run, even if it isn't the original motor. You can always stroke it if you want more cubes and at least it'll look original when you pop the hood.
monaro mark Offline
#8 Posted : Thursday, 22 November 2007 5:48:21 AM(UTC)
monaro mark
If I were you, Id find a correct date code and engine prefix 308 for it. It will be worth more in the long run, even if it isnt the original motor. You can always stroke it if you want more cubes and at least itll look original when you pop the hood.
HQ SAND MAN Offline
#9 Posted : Thursday, 22 November 2007 5:55:10 AM(UTC)
HQ SAND MAN
I understand that the more original the better , where would I start looking for that type of 5.0 a M21 isnt hard too find , The 327 is 60 thou so on the last Bore so I guess when that lets go i will try n find a 5....
monaro mark Offline
#10 Posted : Thursday, 22 November 2007 8:55:23 AM(UTC)
monaro mark
You'd need a 308 with an engine number prefix of QT (not 11QT) and a date code (cast on the front top of your block behind the timing cover) around the same date as your compliance plate.
My Monaros:
- HQ GTS 4 Monaro 350, Auto, Mustar
monaro mark Offline
#11 Posted : Thursday, 22 November 2007 8:55:23 AM(UTC)
monaro mark
Youd need a 308 with an engine number prefix of QT (not 11QT) and a date code (cast on the front top of your block behind the timing cover) around the same date as your compliance plate.
My Monaros:
- HQ GTS 4 Monaro 350, Auto, Mustard
Sandman Offline
#12 Posted : Friday, 23 November 2007 4:21:52 AM(UTC)
Sandman
Guess it depends on how original you want your car.
To change from a chev to a holden engine, you need a fair few parts besides just motor and gearbox. Exhaust changes, wiring, Brackets for alternator, A/C if you have it, radiator, hoses.
My Sandman
HQ SAND MAN Offline
#13 Posted : Friday, 23 November 2007 6:14:13 AM(UTC)
HQ SAND MAN
Yeah im thinking along the same lines as you , The Chev is the way too go and its putting out some resonable H/p it needs a freshen up , but have spken too plenty of people that have seen it go and apparently in full song it gets on with it , is it possib
#14 Posted : Saturday, 24 November 2007 12:38:32 AM(UTC)
monaro mark couldnt there be some way of making any 308 a qt numbered block ? all the best
monaro mark Offline
#15 Posted: : Saturday, 24 November 2007 12:54:27 AM(UTC)
monaro mark
You could restamp the block but it's illegal to do so.
My Monaros:
- HQ GTS 4 Monaro 350, Auto, Mustard, Black Trim
- HQ GTS 4 Monaro 308, Manual, Orchid Metallic, Black Trim
monaro mark Offline
#16 Posted : Saturday, 24 November 2007 12:54:27 AM(UTC)
monaro mark
You could restamp the block but its illegal to do so.
My Monaros:
adam PERTH Offline
#17 Posted : Saturday, 24 November 2007 1:36:47 AM(UTC)
adam PERTH
with an 11QT, you could Bog over the 11, so it starts with QT.
THen paint over it.
Thats the Bogan way....
A1 Bogan.
monaro mark Offline
#18 Posted : Saturday, 24 November 2007 2:48:04 AM(UTC)
monaro mark
Haha
My Monaros:
HQ SAND MAN Offline
#19 Posted : Sunday, 25 November 2007 4:08:23 AM(UTC)
HQ SAND MAN
there has too be a loop hole some where . there normally is ,,, i have heard that when a block is decked it can rmove the eng no ? can any 1 confirm this
monaro mark Offline
#20 Posted : Sunday, 25 November 2007 7:54:36 PM(UTC)
monaro mark
Yeah it can but I think a police acid test would show the original number.
My Monaros:
Guest (11)
This page was generated in 0.129 seconds.
