v8cruisin Offline
#1 Posted : Thursday, 22 November 2007 2:34:22 AM(UTC)
v8cruisin
My VN V6 has just crapped out and I have a HZ ute with SBC that has no trans at the moment. I plan on putting a manual box behind it but just want to get it drivable it at the moment (its already setup for TH400
Does anyone know how much modification is required to Bellhousing of 700R4 to fit chev or if it is possible/other complications?
v8cruisin Offline
#2 Posted : Thursday, 22 November 2007 2:40:58 AM(UTC)
v8cruisin
I am an engineer so can do any modifications myself. If its likely to cost much to fit this auto up, I'll just find another TH400.
v8cruisin Offline
#3 Posted : Thursday, 22 November 2007 2:40:58 AM(UTC)
v8cruisin
I am an engineer so can do any modifications myself. If its likely to cost much to fit this auto up, Ill just find another TH400.
adam PERTH Offline
#4 Posted : Thursday, 22 November 2007 3:20:02 AM(UTC)
adam PERTH
can't use the V6 T700. - smaller pattern
you need a 5Lt T700. - which is the V8 chev pattern.
A1 Bogan.
adam PERTH Offline
#5 Posted : Thursday, 22 November 2007 3:20:02 AM(UTC)
adam PERTH
cant use the V6 T700. - smaller pattern
A1 Bogan.
v8cruisin Offline
#6 Posted : Thursday, 22 November 2007 3:41:48 AM(UTC)
v8cruisin
Oh ok. Thanks very much
HQ SAND MAN Offline
#7 Posted : Thursday, 22 November 2007 5:50:47 AM(UTC)
HQ SAND MAN
Unless your gonna beef up the T700 just dont use it stick with the T400 amd spend the money on that you will end up with an indistructable trans. But just my opinion
v8cruisin Offline
#8 Posted : Thursday, 22 November 2007 7:49:25 AM(UTC)
v8cruisin
It was only going to be temparary, until i get all the bits for my manual ready to put in. Only has a banjo diff atm with 255s on back so gotta be gentle (which will be hard). thanks for your advice though
kanks Offline
#9 Posted : Thursday, 22 November 2007 6:30:28 PM(UTC)
kanks
g day i ran a A STOCK VN T700 V6 BEHIND A MILD 307 WITH NO PROBS AT ALL AND DROVE IT HARD I DID HAVE A ADAPTER PLATE FITTED .I RECENTLY REBUILT ENGINE AND HAD BOX BEEFED UP AS WELL CHERRS
HQ SAND MAN Offline
#10 Posted : Friday, 23 November 2007 6:31:11 AM(UTC)
HQ SAND MAN
Kanks you would be one of very few lol... the T700 is a pig of a trans generally a stock inj 5.0 will chew em up n spit em out on a regular basis , they burn clutches real well ....
LPGPIG Offline
#11 Posted : Friday, 23 November 2007 6:40:41 AM(UTC)
LPGPIG
Hey mate, you can buy an adaptor plate for the V6 t700 form castlemaine rod shop, but the problem is price as it cost's just under $650. Im looking at buying an adaptor kit for the V6 t700 that i have out back for my 253. But im planning on making the box
Edited by user Friday, 23 November 2007 6:42:05 AM(UTC)  | Reason: Not specified
LPGPIG Offline
#12 Posted : Friday, 23 November 2007 6:40:41 AM(UTC)
LPGPIG
Hey mate, you can buy an adaptor plate for the V6 t700 form castlemaine rod shop, but the problem is price as it costs just under $650. Im looking at buying an adaptor kit for the V6 t700 that i have out back for my 253. But im planning on making the box
v8cruisin Offline
#13 Posted : Thursday, 6 December 2007 8:44:33 PM(UTC)
v8cruisin
Sorry, havent been on for a while. Thanks LPGPIG. thats a lot of money for an adaptor plate, I presume it must have a few other bits with it. I have a spare 454 block and crank (which I presume will be same setup as small block), so i guess I could remove
#14 Posted : Thursday, 6 December 2007 10:01:12 PM(UTC)
Was thanked: 559 time(s) in 534 post(s)
It'd be easier and cheaper to just buy a VN-VP V8 box. They are only about $500. Will bolt straight up, but the TH400 crossmember ans tailshaft will be wrong. I'd just get another TH400. At least you won't break it.
____________________________________
#15 Posted : Thursday, 6 December 2007 10:01:12 PM(UTC)
Itd be easier and cheaper to just buy a VN-VP V8 box. They are only about $500. Will bolt straight up, but the TH400 crossmember ans tailshaft will be wrong. Id just get another TH400. At least you wont break it.
v8cruisin Offline
#16 Posted : Thursday, 6 December 2007 10:12:56 PM(UTC)
v8cruisin
Ok thanks for your advice. Only reason why I'd consider doing this is because I've been off work for over 3 months from work accident and have no money. There is a TH400 for $400 local which would be good but still dont have $400 at the moment lol
v8cruisin Offline
#17 Posted : Thursday, 6 December 2007 10:12:56 PM(UTC)
v8cruisin
Ok thanks for your advice. Only reason why Id consider doing this is because Ive been off work for over 3 months from work accident and have no money. There is a TH400 for $400 local which would be good but still dont have $400 at the moment lol
