My VN V6 has just crapped out and I have a HZ ute with SBC that has no trans at the moment. I plan on putting a manual box behind it but just want to get it drivable it at the moment (its already setup for TH400
Does anyone know how much modification is required to Bellhousing of 700R4 to fit chev or if it is possible/other complications?
I am an engineer so can do any modifications myself. If its likely to cost much to fit this auto up, I'll just find another TH400.
I am an engineer so can do any modifications myself. If its likely to cost much to fit this auto up, Ill just find another TH400.
can't use the V6 T700. - smaller pattern you need a 5Lt T700. - which is the V8 chev pattern.
A1 Bogan. |
cant use the V6 T700. - smaller pattern you need a 5Lt T700. - which is the V8 chev pattern.
A1 Bogan. |
Unless your gonna beef up the T700 just dont use it stick with the T400 amd spend the money on that you will end up with an indistructable trans. But just my opinion
It was only going to be temparary, until i get all the bits for my manual ready to put in. Only has a banjo diff atm with 255s on back so gotta be gentle (which will be hard). thanks for your advice though
You are a member of these groups:: Registered
g day i ran a A STOCK VN T700 V6 BEHIND A MILD 307 WITH NO PROBS AT ALL AND DROVE IT HARD I DID HAVE A ADAPTER PLATE FITTED .I RECENTLY REBUILT ENGINE AND HAD BOX BEEFED UP AS WELL CHERRS
Kanks you would be one of very few lol... the T700 is a pig of a trans generally a stock inj 5.0 will chew em up n spit em out on a regular basis , they burn clutches real well ....
Hey mate, you can buy an adaptor plate for the V6 t700 form castlemaine rod shop, but the problem is price as it cost's just under $650. Im looking at buying an adaptor kit for the V6 t700 that i have out back for my 253. But im planning on making the box Edited by user Friday, 23 November 2007 6:42:05 AM(UTC)
| Reason: Not specified
Hey mate, you can buy an adaptor plate for the V6 t700 form castlemaine rod shop, but the problem is price as it costs just under $650. Im looking at buying an adaptor kit for the V6 t700 that i have out back for my 253. But im planning on making the box Edited by user Friday, 23 November 2007 6:42:05 AM(UTC)
Sorry, havent been on for a while. Thanks LPGPIG. thats a lot of money for an adaptor plate, I presume it must have a few other bits with it. I have a spare 454 block and crank (which I presume will be same setup as small block), so i guess I could remove
It'd be easier and cheaper to just buy a VN-VP V8 box. They are only about $500. Will bolt straight up, but the TH400 crossmember ans tailshaft will be wrong. I'd just get another TH400. At least you won't break it.
____________________________________ |
Itd be easier and cheaper to just buy a VN-VP V8 box. They are only about $500. Will bolt straight up, but the TH400 crossmember ans tailshaft will be wrong. Id just get another TH400. At least you wont break it.
_______________________________________ |
Ok thanks for your advice. Only reason why I'd consider doing this is because I've been off work for over 3 months from work accident and have no money. There is a TH400 for $400 local which would be good but still dont have $400 at the moment lol
Ok thanks for your advice. Only reason why Id consider doing this is because Ive been off work for over 3 months from work accident and have no money. There is a TH400 for $400 local which would be good but still dont have $400 at the moment lol
