bundybluedog Offline
#1 Posted : Tuesday, 27 November 2007 12:37:23 AM(UTC)
bundybluedog
Im looking at buying vk 202 carby fed with 5spd to possabley put in a HG sedan the sedan currntly has 186 3speed manual is there anything major i will have to do for this conversion? crosmemebers, linkages ect
dan
vintageholden Offline
#2 Posted : Tuesday, 27 November 2007 12:44:39 AM(UTC)
vintageholden
custom cross member / tailshaft yoke etc
clutch setup..fit the whole brake assembly from the commodore..
do you have disks...
not to hard.....
#3 Posted : Tuesday, 27 November 2007 12:52:39 AM(UTC)
bundybluedog
its has cable clutch on the 5speed car has drum brakes, do the commodore brakes fit?
#4 Posted : Tuesday, 27 November 2007 2:14:10 AM(UTC)
vintageholden
no
update to hk/t/g disks with booster
cable clutch a bit of messing around
drill hole in fire wall etc....if you use the pedals from the commodore you should have no problem..take your out all 3..
and fit the commodore ones around the steering column
#5 Posted : Tuesday, 27 November 2007 11:15:38 AM(UTC)
bundybluedog
cool thanks man
This page was generated in 0.022 seconds.
