witcheshollow racing team Offline
#1 Posted : Tuesday, 27 November 2007 10:02:56 AM(UTC)
As the heading suggest I havea VK Calais 202 efi that is having a variation in RPM's while it sits at idle. Idles fine then raises a few revs then drops back to idling fine and after a few seconds will do it again. Engine has been rebuilt, fuel is a bit low but I dont think its enough to worry about, still 3 red marks on the guage. Any suggestions?
When the green flag drops the bulls@#t stops!!
"Such is life"
HG-PREM Offline
#2 Posted : Tuesday, 27 November 2007 6:31:21 PM(UTC)
HG-PREM
vaccum leak?
Mr Void Offline
#3 Posted : Wednesday, 28 November 2007 12:30:52 AM(UTC)
Mr Void
Could be heaps of things electircally;
TPS - idle contact, AFM (wiring or vacuum), control unit, Air temp sensor (in AFM), coolant temp sensor, Aux air valve circuit, ign coil - control relay circuit, inj circuit.
Faulty EGR, vac advance setup wrong.
Edited by user Wednesday, 28 November 2007 12:32:19 AM(UTC)  | Reason: Not specified
___________________
#4 Posted : Wednesday, 28 November 2007 8:00:43 AM(UTC)
ok will double check vacume hoses, may have missed one or have a split. The change in RPM is not consistant just seems to happen then a minute or so later happens again.
Intrested in the vacume advance as I broke the regulator ontop the thermostat hou
"Such is life"
HQ SAND MAN Offline
#5 Posted : Thursday, 29 November 2007 10:57:36 PM(UTC)
HQ SAND MAN
mine used to do somthing similar but mine did it at take off ,, all i did was chuck about 1/2 a can of thrttle body cleaner into the throttle body and that seemed to fix it after a few drives
#6 Posted : Thursday, 29 November 2007 11:55:50 PM(UTC)
I gave the throttle body a clead out with a bit of WD40 as thats all I had at that stage, living in the country means nothing is open on the weekend, so will try that as it was a bit dirty and had been sitting for a while. Thanks.
"Such is life"
#7 Posted : Sunday, 2 November 2008 10:39:47 PM(UTC)
air intake bolts have been overtightened causing a crack in the air intake -vacuum leak.
Guest (6)
